    Probleme sur l'emulation philips cdi
    lemulation philips cdi
    7
    23
    8391
    • DiamondsR4eveR
      DiamondsR4eveR last edited by
      Salut à tous, enfin on peut jouer au cdi sur recalbox trop bien, sauf je n'est pas de bouton 2 configuré sur mon anbernic rg552 est ce normal .je n'arrive plus a avancer dans Secret Mission
      • Aldébaran
        Aldébaran @DiamondsR4eveR last edited by
        Bonjour @diamondsr4ever,
        Recalbox n'est pas développé sur cette console. Par conséquent nous ne faisons pas de support non plus.
        RustyMG 1 Reply Last reply Reply Quote 0
        • RustyMG
          RustyMG @Aldébaran last edited by RustyMG
          @aldébaran
          Recalbox 8.1-Electron:
          Add Raspberry Pi 4 64 bit support
          Add Recalbox RGB Dual support
          Add system Philips CD-I (libretro core : cdi2015)
          Add support for external rom folders on USB devices (up to 8 volumes/partitions)
          Hotplug: EmulationStation automatically reconize USB device containing roms!
          Initialization: Ask the user when USB device with no rom folders at all
          Roms folders are reconized in the root of the usb device or in roms or recalbox/roms
          Games are merged into your game list seamlessly
          Add support for additional network rom folders (up to 4)
          As for USB devices, games are merged into your game list seamlessly
          Add case support for retroflag, argon and nuxii cases
          Add Pi400 power button support (Fn + F10 to turn off)
          Add remote playlists (Patrons)
          Add seamless scraping (Patrons)
          Add GAME FILTER menu to filter games in lists based on several criteria
          Add slangs shaders support on retroarch
          Add BSNES core (performance build) (PC and RPi4/400)
          Add BSNES HD for wide screen Super Nintendo games (PC and RPi4/400)
          Add libretro PSP emulator (libretro ppsspp)
          Add delete game options
          Add the game Zdey The Game on Nintendo Nes. Thank you Art'cade
          Add core libretro vitaquake2 for x64, RPi4, Odroid Xu4 and Odroid Go Advance/Super
          New system sorting options in UI menu: sort your systems by type, manufacturer, release dates and more !
          Add Iris driver for Intel iGPUs on x64 version
          New option in UI menu : hide PORTS collection
          Add recalbox.conf option to force resolution of splash videos on x64
          New Random game picker in demo mode (less cycling)
          Display game regions flag in gamelist
          Add Twitch as Kodi plugin
          Add resolution menu in Advanced Settings > Resolutions
          Add scraper progress bar
          Add display by filename in gamelist option
          Add go to game from search results and add search games from gamelist menu
          Add retroachievements for systems PSP, Amstrad CPC, Dreamcast, Atomiswave, Naomi and Naomigd
          Add Amiga 500 Mini controller configuration
          Add softpatching manager in game settings
          Add system MegaDuck (libretro core : sameduck) Thanks Duimon for the drawing of the console on the theme.
          Add new Atari 5200 core (libretro core: a5200)
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
          Pitch64 1 Reply Last reply Reply Quote 0
          • Pitch64
            Pitch64 Staff @RustyMG last edited by
            @rustymg We know what we added into Recalbox 8.1, but Anbernic boards are absolutely not supported, and therefore we can't help on it.
            Next release? Soon™
            • JB GARBAY
              JB GARBAY last edited by
              Je profite de ce post sur le CD-i afin de poser une question !
              J'ai lancé MacDog McCreed et après le démarrage cela met un message d'erreur comme quoi je n'ai pas de carte DV ?
              Il y a t'il une manipulation ou bien un bios supplémentaire à ajouter ?
              Ou tout simplement les jeux nécessitant une carte DV à l'époque ne sont pas compatibles ?
              Merci !
              • Pitch64
                Pitch64 Staff last edited by
                Les jeux nécessitant une carte FMV (Full Motion Video) ne sont pas compatibles avec l'émulateur 🙂
                Next release? Soon™
                JB GARBAY 1 Reply Last reply Reply Quote 0
                • JB GARBAY
                  JB GARBAY @Pitch64 last edited by
                  @pitch64 ah ben dommage ! Ce sont les seuls jeux qui m'intéressaient sur ce support !! Tant pis !
                  Merci quand même !
                  • Degrundt
                    Degrundt last edited by Degrundt
                    Salut à tous et désolé par avance si je ne poste pas au bon endroit ou mal à propos !
                    Voici mon problème :
                    Malgré la copie du fichier Cdimono.zip sous quasiment toutes les versions que j'ai pu trouver sur le net, impossible d'obtenir la vérification qui va bien et donc le pouce Vert dans la vérif des BIOS Cdi...
                    merci d'avance pour vos réponses !
                    M__a__a__x 1 Reply Last reply Reply Quote 0
                    • M__a__a__x
                      M__a__a__x Global moderator @Degrundt last edited by
                      @degrundt
                      As tu essayé avec la signature MD5 du bios dans ta recherche ?
                      As tu mis le bios au bon endroit (chemin indiqué dans le vérificateur de bios) ?
                      Recalboxment votre,
                      M__a__a__x
                      Degrundt 2 Replies Last reply Reply Quote 0
                      • Degrundt
                        Degrundt @M__a__a__x last edited by
                        @m__a__a__x Salut et merci pour ta réponse rapide ! Le fichier est au bon endroit à priori et la recherche avec la signature MD5 ne renvoie rien sur Google...Je vais revérifier le chemin car il y a un répertoire share que je n'utilise jamais dans l'arbo (ça ne pose jamais de souci pour les autres émulateurs) qui figure dans le chemin du vérificateur de bios...
                        Degrundt 1 Reply Last reply Reply Quote 0
                        • Degrundt
                          Degrundt @Degrundt last edited by Degrundt
                          "Je vais revérifier le chemin car il y a un répertoire share que je n'utilise jamais dans l'arbo (ça ne pose jamais de souci pour les autres émulateurs) qui figure dans le chemin du vérificateur de bios..."
                          Bon manifestement le répertoire share n'est accessible que via LAN, donc rien à faire de plus concernant l'emplacement du Cdimono1.zip...
                          • Degrundt
                            @m__a__a__x Bon rien à faire... Ça veut pas...
                            • M__a__a__x
                              @degrundt
                              Je vais tenter de regarder de mon coté, tu utilises quelle board ?
                              Recalboxment votre,
                              M__a__a__x
                              • Degrundt
                                @m__a__a__x Rpi4. Merci à toi 😉👍.
                                • M__a__a__x
                                  @degrundt
                                  Tu es dans le bon dossier ? et le bon nom (oublie pas le "1") ?
                                  Recalboxment votre,
                                  M__a__a__x
                                  Degrundt 2 Replies Last reply Reply Quote 1
                                  • Degrundt
                                    Degrundt @M__a__a__x last edited by Degrundt
                                    @m__a__a__x Hello, Bon ben il est clair qu'il y a quelque chose que je ne fais pas correctement...Ou alors c'est mon Cdimono1.zip qui n'est pas le bon. J'ai bien celui qui a 5 fichiers comme requis pourtant...Je vais reprendre tout ça avec un peu de recul. Merci de ton aide en tout cas.
                                    • Degrundt
                                      @m__a__a__x Bon j'ai pigé, je suis teubé...Je m'escrimais à le copier directement sur mon Hdd externe dans le répertoire Cdi/bios...Ce que je fais pour les roms. Sauf que là, il faut procéder via le réseau pour avec le chemin exact share/bios/cdi...
                                      Pas testé pour l'instant mais ce sera bon je pense.
                                      Merci encore pour le temps passé !
                                      • M__a__a__x
                                        @degrundt
                                        Pas de soucis 😉
                                        Tout dépend si ton disque dur est branché à la volé ou comme share principal (une des modification de la version 8.1)
                                        Recalboxment votre,
                                        M__a__a__x
                                        • Degrundt
                                          @m__a__a__x Bon la galère continue 😤... J'obtiens maintenant seulement un pouce jaune et non vert comme sur ta copie d'écran...Et les jeux ne se lancent toujours pas...La signature MD5 n'est pas la bonne et impossible de mettre la main sur une version correcte du Cdimono1.zip...
                                          • M__a__a__x
                                            @degrundt
                                            Pour le bios je ne pourrais pas t'aider plus.
                                            Pour les roms, as tu essayé avec une rom en .chd (quitte à les convertir toi même) ?
                                            Recalboxment votre,
                                            M__a__a__x
                                            Degrundt 1 Reply Last reply Reply Quote 1
