    x86/x64 Recalbox 8.0.1 No network/Pas de réseau
    x86x64 recalbox 8.0.1 networkpas
    • Pablouchka
      Pablouchka last edited by
      I just found out the incredible world of Recalbox and am just amazed by the experience.
      I run Recalbox on my spare PC based on a Gigabyte GA-MA770-UD3 (rev. 1.0) and it looks like the NIC is not supported.
      I also have a WIFI card (Intel Dual Band Wireless-AC 8260) and I am not able to use it.
      Any idea how to "add" a driver to RecalBox ?
      Thanks for all your help 🙂
      Je viens de découvrir le monde merveilleux de Recalbox et je suis tout simplement impressionné par l'expérience.
      J'ai lancé Recalbox sur mon PC secondaire basé sur un Gigabyte GA-MA770-UD3 (rev. 1.0) et il semble que la carte réseau ne soit pas supportée.
      J'ai aussi une carte WIFI (Intel Dual Band Wireless-AC 8260) et je ne suis pas en mesure de l'utiliser.
      Une idée de comment "ajouter" un pilote à RecalBox ?
      Merci pour votre aide 🙂
      • Alvin
        Alvin Banned @Pablouchka last edited by
        @pablouchka
        To make it simple:
        Recalbox is not a Linux like Ubuntu, Debian or Linux Mint where you can install Drivers for your Hardware.
        Recalbox is "just enough Linux" with Build-In Drivers for Graphic, Sound and Network.
        to run the Game-Emulators.
        If your Hardware is not compatible with these Drivers you're out of Luck, because you can't install Drivers by yourself.
        Here
        https://wiki.recalbox.com/en/tutorials/network/wifi/enable-wifi
        you can see how to enable WiFi in Recalbox (but I'm sure you already know this)
        and here
        https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/wifi-dongles
        is a List of all the WiFi-Dongles which are compatible with Recalbox.
        Pablouchka 1 Reply Last reply Reply Quote 1
        • Pablouchka
          Pablouchka @Alvin last edited by
          @alvin Thanks that's a clear answer 😉
          Have a nice day, take care and stay safe !
          • Alvin
            @pablouchka
            You're welcome !
