    x86 / x64 Recalbox 8.0.1 Intel Onboard Graphics Card
    x86 x64 recalbox 8.0.1 intel onboard graphics card
    • Don76
      Don76 last edited by
      Hello all,
      I have the following problem I would like to use the Recalbox Box from USB.
      Unfortunately, it does not work properly with my IntelNUC and the graphics card driver is missing.
      the graphic card is the integrated Intel N6005
      Result of "lspci -nnk | grep -i VGA -A2"
      00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:4e71] (rev 01)
      DeviceName: Intel(R) UHD Graphics Device
      Subsystem: Intel Corporation Device [8086:3027]
      is there any solution here ?
      Kind regards
      Don
      Alvin 1 Reply Last reply Reply Quote -1
      • Alvin
        Alvin Banned @Don76 last edited by Alvin
        @don76 said in x86 / x64 Recalbox 8.0.1 Intel Onboard Graphics Card:
        Great, now we know exactly what kind of Graphic-Card is build into your NUC.
        What we don't know is what "does not work properly" means.
        Is there no Picture at all (Black Screen), is there no Picture when you try playing a Game. is the Picture distorted, got wrong Colors or is it something completely different ?
        "The Graphics Card Driver is missing"
        How do you know that ?
        Did Recalbox tell you ?
        Did Recalbox shows an Error about the Graphics Card at all ?
        The Graphic Card Driver is build into Recalbox, and Recalbox is not Windows where you need a special Driver from the Manufactor of your Graphics Card.
        Here
        https://wiki.recalbox.com/en/hardware-compatibility/compatible-pcs
        you can see which Version of Recalbox is tested and compatible with which Version of the Intel NUC
        • Don76
          First of all, thank you for the feedback
          The problem is generally with the resolution and colour depth. Max800x600 256 colours.
          Although the i915 integrated graphics card driver should fit, it is not initialised.
          For testing I have tested with Ubuntu and Debian. I can get the graphics card to work under both systems.
          The type of graphics chip set is that of the Intel jasperlake.
          Is there an update in progress ?
          Kind regards
          Don
