    I have a bigger SD card than the 128 gb image I first got - how to partition?
    bigger card 128 got partition
    • eroxx
      eroxx last edited by
      I'm on a Mac and it would be the best if there was something on Mac that let me do this? If not, I can use Windows. Thanks!
      RustyMG 1 Reply Last reply Reply Quote -1
      • RustyMG
        RustyMG @eroxx last edited by
        @eroxx If you have Recalbox 7.x or above, easiest thing to do is to put the SD card into a Windows PC, and just copy off your bios and rom folders etc, install Recalbox on your new SD card, let it boot up (to create the reqd folders), and just copy the files back over.
        Yes there are other options, but this is the simplest and easiest.
        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
        eroxx 1 Reply Last reply Reply Quote 0
        • eroxx
          eroxx @RustyMG last edited by
          @rustymg
          Thanks!
          So I don't know if this is an issue or not, but my system was "pre built" - I bought a cabinet that came with the SD card with the image on it, and the settings for controllers/etc are very specific to my system. Is there a way I can save all that too? Thanks!
          Alvin 1 Reply Last reply Reply Quote -1
          • Alvin
            Alvin Banned @eroxx last edited by Alvin
            @eroxx said in I have a bigger SD card than the 128 gb image I first got - how to partition?:
            • I bought a cabinet that came with the SD card with the image on it, and the settings for controllers/etc are very specific to my system.
            Recalbox is FREE and not for Sale, so at last there will be no Support from the "Recalbox-Team".
            It would be the best to ask the Company where you bought your Cabinet for Help and Support.
