    Solarus on X64 PC doesn't works
    Emulator Arcade/PC/Console
    solarus x64 doesnt
    • Pilcrw 0
      Pilcrw 0 last edited by
      HHello Recalbox community,
      I've a problem to run any game on Solarus Emulator (Recalbox image X64 Electron 8.0.1)
      For example, when i want to run Zelda Mystery of Solarus DX, a error box appear with different issues 'bad rom', 'bad bios' ...
      Same problem with other rom too.
      I've check the es_log and a WARN! log is present under the game launch command :
      [2022/05/24 14:41:02.928] (INFO ) : [Run] Command: python /usr/bin/emulatorlauncher.pyc -system solarus -rom /recalbox/share/roms/solarus/zsdx-v1.12.3.solarus -emulator solarus -core solarus -ratio config
      [2022/05/24 14:41:02.928] (INFO ) : [Pad2Keyboard] No pad2keyb configuration.
      [2022/05/24 14:41:02.929] (INFO ) : [CPU] Set performance mode
      [2022/05/24 14:41:02.929] (INFO ) : [MQTT] Publishing to tcp://127.0.0.1:1883 from recalbox-emulationstation OK!
      [2022/05/24 14:41:02.929] (INFO ) : [Hardware] Start in-game Hardware processes
      [2022/05/24 14:41:03.114] (INFO ) : [Hardware] Stop in-game Hardware processes
      [2022/05/24 14:41:03.114] (INFO ) : [CPU] Set powersaving mode
      [2022/05/24 14:41:03.114] (WARN!) : [Run] Non-Zero exit code 250 !
      [2022/05/24 14:41:03.114] (INFO ) : [MQTT] Publishing to tcp://127.0.0.1:1883 from recalbox-emulationstation OK!
      Have you some idea to resolv for this issue?
      Thanks for your great job and i'le be glad to read you !
      Regards,
      Pilcrw.
      Alvin 1 Reply Last reply Reply Quote -1
      • Alvin
        Alvin Banned @Pilcrw 0 last edited by
        @pilcrw-0
        Well, it seems that is one of the Bugs the new Recalbox hast to offer:
        Look here
        https://forum.recalbox.com/topic/25536/recalbox-8-0-black-screen-on-solarus-games
        https://gitlab.com/recalbox/recalbox/-/issues/1888
        tegunwale 1 Reply Last reply Reply Quote 0
        • tegunwale
          tegunwale @Alvin last edited by
          @Alvin said in Solarus on X64 PC doesn't works:
          @pilcrw-0
          Look here
          https://forum.recalbox.com/topic/25536/recalbox-8-0-black-screen-on-solarus-gamesbasketball legends
          I do not think so. This error occurs due to connection or because the login device has not been updated or is not compatible with the software. Not Recalbox's fault.
