    Picade Joystick
    picade joystick
    • romka
      romka last edited by
      Hi, guys, I've put together Picade cabinet and installed Recalbox 4.o. Works great except for the joystick itself. It works in the menus, but not in the games. I also added XBOX 360 wireless controller and that works just fine both in menus and games. But would love to have that joystick working too. Please, help?!! Thanks, R
      • romka
        anyone?...
        • nosfay
          nosfay last edited by
          Does your joystick wired on GPIO ? If yes, did you activate it in recalbox.conf?
          ## GPIO Controllers
          controllers.gpio.enabled=1
          • romka
            Many thanks! That did the trick! One more question. Sounds seems to work only via Audio Jack, no HDMI. is it the way it should be? Thanks, R.
            • nosfay
              You're welcome 🙂 For HDMI sound, try to force it by editing this section like that:
              audio.device=hdmi
              If you want to know more about recalbox configuration, take a look at this wiki page !
