    Arch Linux Desktop
    arch linux desktop
    • nickdj
      nickdj last edited by
      I would really like to have the ability to use RecalBox and a Linux desktop environment. At first I thought maybe I could add another OS to NOOBs and then have a choice at start-up, but this didn't work. I then thought about Berryboot, but I'm struggling to work out how to convert to squashfs correctly. I would prefer to use Arch Linux so my last thought was to install a desktop environment with the intention of being able to quit Recalbox and boot to the desktop from command line. Is there a way to get a desktop environment alongside Recalbox? Any help will be much appreciated.
      RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
      • digitaLumberjack
        Hi, never a window manager will be integrated to recalbox. You must understand that i want to make a video game console from the rpi, not a second raspian + retorpie. But you can try to dual boot recalboxOS with raspbian, by copying recalboxOS noobs files (in "os/recalboxOS") in a noob "os" directory.
        • nickdj
          Thanks for the reply. I didn't want a window manager incorporated into the Recalbox just wanted to know if there was a way I could add one manually. It was more so I could learn about Recalbox and see if I can add my own features to it. 🙂 I will see if I can get a dual boot to work and go from there.
          • LucasFebatis
            LucasFebatis last edited by
            A window manager would be very useful for me, I am a software developer and I created a simple snake game with Java Swing and I would like to run it on my Recalbox, apparently, I will have several hours of work having to install Raspbian and manually configure EmulationStation to call my game in java
