    [DosBox] MIDI MPU-401 on Raspberry Pi
    Emulator Arcade/PC/Console
    [dosbox] midi mpu-401 raspberry pi
    3098
    • Xerobit
      Xerobit last edited by Xerobit
      Is it possible to use a MIDI emulator with Recalbox, on a Raspberry Pi, that can be detected by DosBox?
      @chacs asked a related question in 2018, and noted, "Under Windows, DosBox goes through the 'midi drivers' of the PC sound card, but under Recalbox/Raspberry, I suppose it must be different."
      @lmerckx responded with, "It's probably a DosBox compile-time option that hasn't been enabled. We should look into it sometime..."
      I was hoping a solution had been implemented that would allow me to play some of my old non-scummvm games such as Wing Commander, X-Wing, etc. with their glorious MIDI music.
      From my own research into the issue, it appears an emulator, such as munt, or fluidsynth, is needed. Once one of the emulators is running, and the necessary roms and a soundfont are provided, the MIDI device can be detected in DosBox, using the command mixer /listmidi to get the midiconfig= entry in the dosbox.cfg file for the game. Or at least that's how it's done with Windows and DosBox; I'm not sure how Recalbox would do it.
      Does Recalbox already have a MIDI emulator running?
      Has a DosBox compile-time option been found and enabled?
      If so, is there a configuration option we need to enable, to make DosBox, running inside Recalbox, see it?
      • Alvin
        Alvin Banned @Xerobit last edited by Alvin
        @xerobit
        In
        https://wiki.recalbox.com/en/tutorials/games/guides/dos/dosbox-to-play-with-dos-games
        it says:
        "You arrive in the game configuration program. This one is especially interesting to configure the sound.
        Each "setup" is different but in general you are offered a menu in English with "setup sound...".
        You have to select (for the "midi" AND for the "sound effect" if the difference is made) the "Sound Blaster 100% compatible" input and the automatic setting (or failing that, all the default choices that you will be offered)."
        Xerobit 1 Reply Last reply Reply Quote 0
        • Xerobit
          Xerobit @Alvin last edited by
          @alvin Yes, I tried selecting the midi options in the game configuration, but similar to @chacs, I get no music sound. The digital speech and sound effects for the SoundBlaster work though.
          Those results are what led me to do the research, and discover the mixer /listmidi command, which I tried and found out that DosBox does not list any midi devices. It is possible to do this by putting the following commands in the dosbox.bat file:
          mixer /listmidi
          pause
          Since there are no midi devices available to DosBox, I have nothing available to enter in the midiconfig= line of the dosbox.cfg. I am wondering how do I get a midi device to be available in DosBox, and DosBox suggestions are to run a midi emulator like munt or fluidsynth.
          So, is it possible to use a MIDI emulator with Recalbox, on a Raspberry Pi, that can be detected by DosBox?
          • JarebHigonnet
            JarebHigonnet last edited by
            Hey thanks for the special and helpful reply. In this you described very well. I have been reading all details you described here. If I want any more guideline I will contact you here floridaloteryresults .com
            • RosalynZhan
              RosalynZhan Banned last edited by
              This post is deleted!
              • CrossEdward
                CrossEdward Banned last edited by
