    Controllers and MCP23017 on I2C0
    GamePad/GPIO/USB encoder
    mcp23017 i2c joystick
    • Robulle
      Robulle last edited by
      Hi !
      I made a diy arcade cab with a CRT screen, a raspberry PI3B+, a RGB-PI+ board and the RGB-PI OS.
      Since Recalbox is now compatible with CRT I decided to upgrade my cab with the version 8.0.2.
      Analog video output works great but controllers are not detected.
      On the RGB-PI+ joysticks and buttons are connected to IO expanders MCP23017 at 0x20 and 0x21 addresses on I2C0 bus (GPIOs of I2C1 are used for video sync).
      I replaced the mk_arcade_joystick_rpi.ko file of recalbox by the mk_arcade_joystick_rpi.ko file of RGB-PI OS and
      changed the recalbox.conf file with controllers.gpio.enabled=1 and controllers.gpio.args=map=0x20,0x21 but controllers are still not detected.
      Any ideas ? Thanks !
        Zing Global moderator Translator @Robulle last edited by
        @robulle Please, don't SPAM:
        https://forum.recalbox.com/topic/26845/joysticks-sur-mcp23017
        • Locked by  Zing Zing
