    Bluetooth connection 8Bit Pro
    GamePad/GPIO/USB encoder
    bluetooth connection 8bit
    • plofkonijn
      plofkonijn last edited by Zing
      Hello!,
      Ive finally set up my raspberry with recalbox, and installed it on an superpi 4 case, im verry happy with it and the emulation is great!.
      But ive found an issue. The bluetooth range isnt that far of the raspberry, and i want to sit on the couch. I can, but the imput is going to be verry shocky, or it doesnt register the imputs. When i get closer to the console it works flawless.
      Can i install a bluetooth dongle to have a greater range? Ive insert a dongle, but im not sure how to install that now recalbox is on the system.
      Best regards,
      Christiaan
        Zing Global moderator Translator @plofkonijn last edited by
        @plofkonijn
        https://forum.recalbox.com/topic/26184/logitech-k380-bluetooth-keyboard-recalbox-8-rpi4
