    Apple 2 not starting any ROMS
    Emulator Arcade/PC/Console
    apple starting roms
    • ngiri67
      ngiri67 last edited by
      Re: Apple2 doesn't work
      I see this has been dealt with before, however, I am running Recalbox on a PC, and when I try any of the Apple 2 roms included or others I already have, I get a screenful of @ with the GSPLUS BIOS and checkerboards and @'s with Linapple. The whole PC just hangs and I need to reboot.
      Should I get a new copy of the BIOS?
      Any help would be greatly appreciated.
      • Alvin
        Alvin Banned @ngiri67 last edited by Alvin
        @ngiri67
        @ngiri67 said in Apple 2 not starting any ROMS:
        Here
        LinApple
        https://wiki.recalbox.com/en/emulators/computers/apple-2/linapple
        and there
        GSPlus
        https://wiki.recalbox.com/en/emulators/computers/apple-2/gsplus
        it says you don't need any special BIOS-File to play Apple 2 Games on Recalbox
        So why did you want to get a "new Copy of the BIOS" ?
        You can check if you need a BIOS and if you got the right one (not only by Name but by MD5-Checksum too) in the Recalboy Main Menu.
        Did your Games have the rigth Extension and did you put them in the right Folders (see Links above) ?
        ngiri67 1 Reply Last reply Reply Quote 0
        • ngiri67
          ngiri67 @Alvin last edited by
          @alvin said in Apple 2 not starting any ROMS:
          @ngiri67
          Here
          LinApple
          and there
          GSPlus
          Thank you @alvin. I did see they said a BIOS isn't required, but I'm getting a screenful of checkerboard and @ signs and the PC freezes. Even the games that come by default give the same result. I managed the get the 2GS to play the games, but not linapple. I've attached a screenshot in case it might help.20220422_140646 (1).jpg
          Scavy Alvin 2 Replies Last reply Reply Quote 0
            Scavy Global moderator @ngiri67 last edited by
            @ngiri67
            Hi,
            i got this issue once, but i don't remember what was the solution...
            Could you check the extensions of your games ?
            Or i guess they are zipped. Could you try with unzipped files ?
            Thanx.
            • Alvin
              @ngiri67
              Here
              LinApple
              and there
              GSPlus
              Look here at the last Picture on the LinApple Homepage
              http://linapple.sourceforge.net/screenshots.html
              Looks almost the same like your Screenshot but on the whole Page it's never been explained why this happend.
