    Apple2 doesn't work
    Emulator Arcade/PC/Console
    apple2 doesnt
    • Ernisius
      Ernisius last edited by
      Every apple 2 game I try, the emulator starts but I get a screen full of '@''s.
      Also I then can't exit the emulator and need to reboot.
      There is nothing in the readme about a bios file, but I added Rom1 for apple 2 anyway. I had similar issue with batocera and this file fixed it, but did nothing in recalbox.
      Running on a Pi400 4gb memory.
        Scavy Global moderator @Ernisius last edited by
        @ernisius hi
        i already got this issue, but i can't remember what i've done to avoid it...
        The bios is correct ? Do you use any overlay maybe ?
        Ernisius 1 Reply Last reply Reply Quote 0
        • Ernisius
          Ernisius @Scavy last edited by
          @scavy . It's a clean install. All I did was copy the files over.
          But. I just found out I can switch emulators. the default is GSPlus, which doesn't work. I switched it to Linapple and now it does.
          Thanks
            @ernisius it's right, lineapple is a better emulator. Have fun ^^
