    Amiga emulator choice and resolution
    amiga pal puae uae4arm
    • subcriminal
      subcriminal last edited by subcriminal
      Hi, I've installed 8.0.2 on a Pi4 with Pi2SCART but I'm struggling with Amiga emulation. I'd like to run it in native PAL resolution rather than 240p. Where do I edit the mode line please to change this? Changing the resolution in the core causes it to display out of the viewport. Also in ES advanced options I can't change emulators to Amiberry or PUAE, ideally I'd like to use PUAE as my pi3 setup had the CPU scaled to A500 speed but set as A1200 for whdload which makes 3D games like stunt car racer run full speed. At the moment uae4arm loads no matter what emulator I choose in ES. Any help would be much appreciated, coming from Retropie CRT Evo is a bit of a learning curve.
      subcriminal 1 Reply Last reply Reply Quote 0
      • subcriminal
        subcriminal @subcriminal last edited by
        No worries, installed RGB-PI OS4 and everything looks how it should 👍
