    start.elf: is not compatible
    start.elf
    • rstephenson187
      rstephenson187 last edited by
      Hi all,
      new here and new to the Pi.
      just a onetime project to build an arcade machine. But really need some help.
      I downloaded 'wolfanoz-returns-512gb-total-recall-recalbox-image-for-sd-or-ssd'
      used the Raspberry Pi Imager to extract the image to a 1tb card
      I plugged it into my new and only Pi 4 4gbRAM Model B
      I assume from the image filename that it is the RECALLBOX OS
      Unfortunately it does not work
      This board requires newer software...
      Is there anyway to fix this without downloading another image?
      I would like to stick with the one I have, it has a lot of games I want
      Also it took sometime to download so now I feel committed.
      I have tested the Pi with another card and all works fine..
      Thanks all!
      • Bkg2k
        Bkg2k Staff @rstephenson187 last edited by
        Hello @rstephenson187
        First of all, the image you downloaded is not Pi4 compatible.
        Then, Recalbox is not associated in any way with the website from wich you downloaded your image. It contains lots of copyrighted materials!
        We strongly encourage you to download, install & use the official image available at http://www.recalbox.com and then, install your game by yourself.
        • Locked by  Bkg2k Bkg2k
