    Recalbox 8.0.2 RPI4 no HDMI sound
    recalbox 8.0.2 rpi4 hdmi sound
    5457
    • nbarth78
      nbarth78 last edited by
      Dear community,
      The issue is simple : no audio signal through HDMI.
      I have searched a long time before posting, I can't find how to fix this issue.
      I have been using recalbox since a long time, on RPI3 and RPI4.
      I never had such issue before recalbox 8.
      I have tested the following :
      • forcing HDMI in http://recalbox web page
      • installing a new 8.0.2 on the SD Card (instead of upgrading)
      • in the file /boot/config.txt, I have put in comment this line #hdmi_force_hotplug=1
      • in recalbox UI, I am not able to switch from "jack" to "HDMI" (HDMI is not shown)
      If anyone could help ??
      • Alvin
        Alvin Banned @nbarth78 last edited by
        @nbarth78
        Question:
        If you're using a Raspberry Pi 4 did you use the HDMI-Port near the USB-Powerconnection ?
        nbarth78 1 Reply Last reply Reply Quote 0
        • nbarth78
          nbarth78 @Alvin last edited by
          @alvin I tried both hdmi outputs
          Thanks for the hint, but it did not change anything while changing the hdmi output
            Scavy Global moderator @nbarth78 last edited by Scavy
            @nbarth78 hello
            in the ES menu, the HDMI output is selected ? does it appear in the sound menu ?
            • nbarth78
              nbarth78 @Scavy last edited by
              @scavy
              Thanks for your answer
              No it is not shown, I explained it in my original post
              -> in recalbox UI, I am not able to switch from "jack" to "HDMI" (HDMI is not shown)
                @nbarth78
                So i guess there might be a problem :
                • with the hdmi input (in your screen) or
                • with the hdmi output (from your Pi) or
                • the hdmi cable may be damaged.
                  Could you check them ?
                • nbarth78
                  @scavy
                  The problem appeared after upgrading to 8.0.0, 8.0.1 and 8.0.2
                  Before I had sound through HDMI and the hdmi was alteady not shown.
                  But ok, I will check what you propose and keep this thread updated
                  Alvin Scavy 2 Replies Last reply Reply Quote 0
                  • Alvin
                    Alvin Banned @nbarth78 last edited by Alvin
                    @nbarth78
                    One Question that comes to my Mind:
                    What kind of TV/Monitor did you use ?
                    Full HD, 4K or something else ?
                    Maybe Recalbox got some Problems with the EDID https://en.wikipedia.org/wiki/Extended_Display_Identification_Data
                    send by your TV/Monitor ?
                    Have you tried to reset your Recalbox to "Factory Settings" ?
                    https://wiki.recalbox.com/en/basic-usage/features/reset-to-factory-settings
                      @nbarth78 said in Recalbox 8.0.2 RPI4 no HDMI sound:
                      on all these versions, the hdmi output appears at home, there's a problem. Could you post an archive support please ?
                      https://forum.recalbox.com/topic/4054/a-lire-avant-de-poster-merci
                      (translate the archive support part)
                      • nbarth78
                        @scavy
                        I checked again the HDMI connections and after unplugging, plugging again it worked.
                        So thank you for your help
                          @nbarth78 there may be a bad contact somewhere. Anyway, when plugged correctly the hdmi is detected 🙂 Great it works 🙂
                          • recalboxfan1
                            recalboxfan1 last edited by recalboxfan1
                            I’ve experienced the “missing HDMI” option when my TV is turned off (or perhaps on the wrong input??) while the Recalbox is booting. Not sure on the exact timing but it’s definitely fixable 100% of the time if the TV is turned on first.
                            I didn’t used to have this issue before 8.x series Recalbox so not sure what may have changed in I guess the RPi firmware or perhaps the Linux kernel side. I suspect the hdmi_forceplug or one of those boot options will fix the issue but I no longer use HDMI so can’t test.
                            Heck, you could even use a boot option to lock-in HDMI as the only audio choice if you don’t care about easy access to the audio jack functionality!
