    Dreamcast not showing up
    Emulator Arcade/PC/Console
    dreamcast showing
    7835
    • jadamcyk
      jadamcyk last edited by
      Hi, i'm running a RPI4 and Recalbox 8 and just added roms to the Dreamcast folder but the system is not showing up in the menu or in the bios menu. Is there something i'm missing to make this run?
      Alvin Scavy 2 Replies Last reply Reply Quote 0
      • Alvin
        Alvin Banned @jadamcyk last edited by Alvin
        @jadamcyk
        For Information about Dreamcast look here
        https://wiki.recalbox.com/en/emulators/consoles/dreamcast/libretro-flycast
        1, Did you chose the right Emulator ?
        Libretro Flycast is the only one which will work on a Raspberry Pi 4 with Recalbox 8
        1. Did you have the right BIOS ?
          Not only by Name but by MD5 Checksum ?
          You can check it in the Main Menu of Recalbox
        2. Did your ROMs have the right File Extension and did you put them in the right Folder ?
          Check with the Link above
        3. Did you refresh your Gamelist in Recalbox ?
          Main Menu -> UI Settings -> Refresh Gamelist
          Scavy Global moderator @jadamcyk last edited by
          @jadamcyk @Alvin hello
          The system appears if at last one rom with the required extension is in the folder. The readme file contains infos about the extensions. The bios doesn't allow the system to appear.
          You can also check if the gamelist only option is enable or disable.
          If enable, the system only reads the gamelist file and only the games included in the gamelist file will appear.
          jadamcyk 1 Reply Last reply Reply Quote 0
          • jadamcyk
            jadamcyk @Scavy last edited by
            @scavy its showing up now, but roms for DC and Naomi arent loading. It is saying the MD5 isn't matching?
            Do you know what I need to do? see below.
            Dreamcast
            - Dc_flash.bin doesn’t match md5
            Naomi
            - Missing naomi.zip
            - Airlbios.zip doesn’t match md5
            - Hod2bios.zip doesn’t match md5
              @jadamcyk if the bios md5 signature is not matching, that means this is not the right bios. Look for the one with the good md5, and verify that is is well named.
              • jadamcyk
                @scavy This is my first time doing this. How do I find the one with a good md5 and how do I verify the name?
                Zing Alvin 2 Replies Last reply Reply Quote 0
                  Zing Global moderator Translator @jadamcyk last edited by
                  @jadamcyk BIOS are copyrighted, which is why they are not distributed with Recalbox, and similarly why it is not allowed to request or distribute links to BIOS or ROMS here on the forum.
                  You should get the BIOS yourself, I'm sure most of them you can find on google searching for MD5.
                  To help you:
                  https://wiki.recalbox.com/en/basic-usage/features/bios-manager
                  • Alvin
                    @jadamcyk
                    Like Zing said you must search for the BIOS by yourself.
                    Here
                    are the MD5 Checksums for the BIOS listed.
                    If you want to check the MD5 Checksum you can use this Tool
                    https://emn178.github.io/online-tools/md5_checksum.html
                    • jadamcyk
                      jadamcyk @Alvin last edited by
                      @alvin Do you have a link for roms that work?
                      • Pitch64
                        Pitch64 Staff last edited by
                        We do not provide any rom link, please do not ask for it. Thanks 🙂
                        Next release? Soon™
                        • Alvin
                          Alvin Banned @Pitch64 last edited by Alvin
                          @jadamcyk
                          Sorry, but Pitch64 is right, you have to search for yourself !
                          • jadamcyk
                            @alvin Bios are correct and green check mark, roms loaded but they won't start. I've tried several different from packs but nothing working.
                              @jadamcyk check dreamcast roms coming from the redump romset.
