    Issues with 8bitdo USB dongle / adapter
    GamePad/GPIO/USB encoder
    8bitdo usb dongle adapter
    • fh1105
      fh1105 last edited by
      Hello!
      I'm having trouble with my current setup:
      RPi 3B+
      Recalbox 8.0.2 Electron
      2x 8BitDo SN30 Pro wireless
      2x 8BitDo USB adapter
      I can successfully pair the SN30s to the adapters (one to each of them), but Recalbox has a hard time recognizing the USB adapters. Sometimes, it will recognize them as "8bitdo adapter", sometimes as "XBox 360 controller", regardless of what mode I wake the SN30s up to. I tried with Start+X and Start+B, but both are not really working well. Currently, my best guess is to physically disconnect the USB adapters, reconnect them and then hope. But maybe there's a better solution?
      Thank you!
      Zing matthewbstanton Nanaki 3 Replies Last reply Reply Quote 1
        Zing Global moderator Translator @fh1105 last edited by
        @fh1105 See if that helps:
        https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/8bitdo-on-recalbox
        • matthewbstanton
          matthewbstanton @fh1105 last edited by
          @fh1105 I had the same issue, I had to manually change the dongle to d-input mode (not the same as setting the controller to d-input mode), no issues after doing that.
          https://support.8bitdo.com/Manual/USB-Adapter-2/xbox-windows.html
          • Nanaki
            Nanaki Staff @fh1105 last edited by
            @fh1105 Hello
            Please note you have to press the B or X button before you press Start.
            If you press Start + B or Start + X at the same time, there are chances your gamepad detects the Start button first and won't take the B/X button in account.
            Pressing only Start turns on the gamepad but activate the last configured mode.
