    Question: Setting controller order/priority via commandline?
    GamePad/GPIO/USB encoder
    setting orderpriority commandline
    • Cacodaemon
      Cacodaemon last edited by
      Hello,
      I am the proud owner of a GPi CASE 2, and I have got one problem when connection the case to its docking station.
      The "build in" controller remains on it's slot/position and the controller connected via USB becomes the secondary controller.
      When starting a game it may be uncontrollable until the priority is changed via the UI's controller setting. Which can be confusing, hence the internal controller is named "Xbox 360 Controller" as well as the one connected via USB 😕 .
      I would like to change the controller slots whether it's connected to the docking station or used in handheld mode.
      Is there any kind of CLI for configuring the controller settings, otherwise is there a another approach than messing up the config files?
      I figured out that the controller config get stored in /recalbox/share/system/recalbox.conf and the handheld's controller id is 030000005e0400008e02000014010000, I assume that each GPi CASE 2 controller has the same id.
      grep "Xbox 360 Controller" /recalbox/share/system/recalbox.conf
      emulationstation.pad0=030000005e0400008e02000020010000:Xbox 360 Controller
      emulationstation.pad1=030000005e0400008e02000014010000:Xbox 360 Controller
      So my current approach would be to execute a script like this, below (not tested) when connected to the docking station, to swap the controller order:
      /etc/init.d/S31emulationstation stop
      sed -i 's/pad0/pad99/g' /recalbox/share/system/recalbox.conf.bak
      sed -i 's/pad1/pad0/g' /recalbox/share/system/recalbox.conf.bak
      sed -i 's/pad99/pad1/g' /recalbox/share/system/recalbox.conf.bak
      /etc/init.d/S31emulationstation start
      Any other ideas how to manage the controller and swap their order?
      Thanks!
        Zing Global moderator Translator @Cacodaemon last edited by
        @cacodaemon Sorry, but unfortunately I don't know any other way to switch controls than manually.
