    Nintendo 3DS Roms
    nintendo 3ds roms
    • salvo
      salvo last edited by
      Dear all,
      I've just installed Recalbox and I've seen in the supported system list that the Nintendo 3DS is supported, I downloaded a few roms but now I cannot find the Nintendo 3DS folder in the Emulator's rom folder, could you help me, please?
      Thank you in advance.
      Regards
      • Alvin
        Alvin Banned @salvo last edited by
        @salvo
        Sorry, I'm a little bit confused, because I'm still using Recalbox 6.
        From which place did you get the Info that you can play Nintendo 3DS Games on Recalbox ?
        And on which System did you install Recalbox ?
        Raspberry Pi, PC or anything else ?
        Here
        https://www.recalbox.com/database/
        it says "Nintendo DS" only
        For more Information look here
        https://forum.recalbox.com/topic/25827/nintendo-ds-and-3ds-emu-pi-4b-2gb-recalbox-8
        And here
        https://wiki.recalbox.com/en/hardware-compatibility/emulators-compatibility
        it says "No Nintendo DS" on Raspberry Pi
        Pitch64 1 Reply Last reply Reply Quote 0
        • Pitch64
          Pitch64 Staff @Alvin last edited by
          @alvin The information is on the website and is a mistake. It should be removed from that place.
          We don't support 3DS at all, too recent.
          Next release? Soon™
          salvo 1 Reply Last reply Reply Quote 0
          • salvo
            salvo @Pitch64 last edited by
            @pitch64 thanks dear.
            BR
