    Lr-swanstation, poor performance on RPi3&Rpi4.
    Emulator Arcade/PC/Console
    lr-swanstation poor performance rpi3rpi4
    • bluestar
      bluestar last edited by
      Hi all.
      I have problem with lr-swanstation and Duckstation, the performance is poor(frame drops, choppy sound) more on swanstation and less on duckstationon, both Pi3 and Pi4. On Pi3 the problem is way more noticable because is more weak.
      I have test both emulators on the same hardware with different Oses and the problem doesn't exist here (on the the Pi4 all games are running flawless).
      I have try to do clean install, new sd-cards different Tv's but the problem is the same.
      I believe that the thing that does affect performance is the pulse audio driver in the retroarch. When i change it to alsathread driver , the frames go up again and the games running perfect but i don't have sound . I can't use pcsx-rearmed, because the games that i am trying to play they doesn't work with this emulator.
      Is there something that i can do to fix this issue ?
      Zing toniosj 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @bluestar last edited by
        @bluestar Try with another emulator like PCSX-ReARMed.
        Check the documentation if there are any options you don't know about:
        • https://wiki.recalbox.com/en/emulators/consoles/playstation-1/duckstation
        • https://wiki.recalbox.com/en/emulators/consoles/playstation-1/libretro-swanstation
        • toniosj
          toniosj Spanish moderator @bluestar last edited by
          @bluestar What game?
          bluestar 1 Reply Last reply Reply Quote 0
          • bluestar
            bluestar @toniosj last edited by bluestar
            @toniosj
            The first Medal of Honor , Gran Turismo 2 and many others. I have reported it and on the gitlab https://gitlab.com/recalbox/recalbox/-/issues/2183
            toniosj 1 Reply Last reply Reply Quote 0
            • toniosj
              @bluestar It will be fixed with Swanstation on 8.1
