    1/3rd black Screen at top HDMI to DVI raspberry pi 3
    13rd top hdmi dvi
    1125
    • xs2ahmed
      xs2ahmed last edited by xs2ahmed
      I just installed recalbox 8.0.2 raspberry pi 3, the display has a DVI input and I am using an HDMI to DVI adapter for the display. At boot display is fine then the display is 1/3rd black at top and remaining displays the screen. How to solve it ?
      Earlier I was using raspberry pi 2 and recalbox version 8.0.1 and it was working fine with same display on DVI,
      Zing MaxBoun 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @xs2ahmed last edited by
        @xs2ahmed
        https://wiki.recalbox.com/en/tutorials/video/display-configuration
        • MaxBoun
          MaxBoun @xs2ahmed last edited by
          @xs2ahmed I have exactly the same problem, didn't manage to fix it testing different configurations.
            Zing Global moderator Translator @MaxBoun last edited by
            @maxboun And Without DVI X HDMI adapter, on another TV, does it work?
            MaxBoun 1 Reply Last reply Reply Quote 0
            • MaxBoun
              MaxBoun @Zing last edited by
              @zing it's a bartop. Didn't want to move everything.
                Zing Global moderator Translator @MaxBoun last edited by Zing
                @maxboun
                The tutorial information should be enough to solve this problem.
                Well, describe what you tried, how you tried, in detail, so that I know if you did something wrong, or forgot to test an option.
