    Retrobit Gamecube controler : C-stick not working
    GamePad/GPIO/USB encoder
    retrobit gamecube controler c-stick
    2148
    • juluss
      juluss last edited by
      Hi !
      So I bought this Retrofit Gamecube USB controller. It's this one : https://www.amazon.ca/-/fr/RET00068/dp/B074CPY67J
      I can't find it on Retro-bit web site... which is weird, but ok why not.
      When I try to configure the gamepad on Recalbox, and/or directly in Dolphin, I can map every button, except the C-stick left/right. I tried to plug the controller on my Mac and the C-stick button seems to be working. I even tried to edit the GCPadNew.ini file but it's not working. It appears the c-stick left/right is just not working on Recalbox or Linux.
      It's annoying because I obviously bought this controller specifically to play Gamecube games on the Recalbox 😕
      I don't know if the C-stick is really needed on much games, but still.
      Anyone has an idea to help me there ?
      I'm still searching, but I don't know what to do now I can't even find the controller on Retro-bit web site...
        Zing Global moderator Translator @juluss last edited by
        @juluss See if any of these links help:
        • https://forum.recalbox.com/topic/25937/specific-input-config-for-gamecube
        • https://forum.recalbox.com/topic/25880/game-cube-keeps-giving-me-this-error-when-loading-games
        • https://wiki.recalbox.com/en/emulators/consoles/gamecube/dolphin
        • https://wiki.recalbox.com/en/tutorials/games/guides/gamecube-wii/use-original-gamecube-controllers
        • juluss
          Hi !
          Thanks for your answer. I took a look at the links you posted but it was not really helpful. (FYI, I posted the first one 😛 )
          So I went and did more research yesterday. First, when I do a jstest, I can see all button or axes are working, but not the C-stick left/right. And I know because I test all stick, that the c-stick left/right should be axe 2. But nothing is happening when I move the c-stick on that axis.
          I tried the gamepad on MacOS and Windows and the c-stick is working fine on every axis. So we can assume the gamepad is not broken or something like that. It has to be with the driver or the way Linux/Recalbox read the device.
          Let's try if we can read the device.
          First, let's find out where events for that device go :
          # ls -lattr /dev/input/by-id/usb-0079_Generic_USB_Joystick-event-joystick
          lrwxrwxrwx    1 root     root            10 Jan 23 19:54 /dev/input/by-id/usb-0079_Generic_USB_Joystick-event-joystick -> ../event10
          Now we can read the device :
          # hexdump /dev/input/event10
          0000000 adb0 61ed 0000 0000 946b 0000 0000 0000
          0000010 0003 0002 0081 0000 adb0 61ed 0000 0000
          0000020 946b 0000 0000 0000 0000 0000 0000 0000
          0000030 adb0 61ed 0000 0000 b3a0 0000 0000 0000
          0000040 0003 0002 0080 0000 adb0 61ed 0000 0000
          0000050 b3a0 0000 0000 0000 0000 0000 0000 0000
          0000060 adb0 61ed 0000 0000 f22e 0000 0000 0000
          0000070 0003 0002 007f 0000 adb0 61ed 0000 0000
          0000080 f22e 0000 0000 0000 0000 0000 0000 0000
          0000090 adb0 61ed 0000 0000 30ad 0001 0000 0000
          00000a0 0003 0002 0080 0000 adb0 61ed 0000 0000
          00000b0 30ad 0001 0000 0000 0000 0000 0000 0000
          00000c0 adb0 61ed 0000 0000 a7aa 0002 0000 0000
          00000d0 0003 0002 0081 0000 adb0 61ed 0000 0000
          00000e0 a7aa 0002 0000 0000 0000 0000 0000 0000
          00000f0 adb0 61ed 0000 0000 c6cb 0002 0000 0000
          0000100 0003 0002 007f 0000 adb0 61ed 0000 0000
          0000110 c6cb 0002 0000 0000 0000 0000 0000 0000
          0000120 adb0 61ed 0000 0000 e62a 0002 0000 0000
          0000130 0003 0002 0080 0000 adb0 61ed 0000 0000
          0000140 e62a 0002 0000 0000 0000 0000 0000 0000
          0000150 adb0 61ed 0000 0000 24a9 0003 0000 0000
          0000160 0003 0002 0081 0000 adb0 61ed 0000 0000
          0000170 24a9 0003 0000 0000 0000 0000 0000 0000
          0000180 adb0 61ed 0000 0000 43dd 0003 0000 0000
          0000190 0003 0002 0080 0000 adb0 61ed 0000 0000
          00001a0 43dd 0003 0000 0000 0000 0000 0000 0000
          00001b0 adb0 61ed 0000 0000 5724 0005 0000 0000
          00001c0 0003 0002 007f 0000 adb0 61ed 0000 0000
          00001d0 5724 0005 0000 0000 0000 0000 0000 0000
          00001e0 adb0 61ed 0000 0000 7665 0005 0000 0000
          00001f0 0003 0002 0080 0000 adb0 61ed 0000 0000
          0000200 7665 0005 0000 0000 0000 0000 0000 0000
          0000210 adb0 61ed 0000 0000 ce24 0006 0000 0000
          0000220 0003 0002 007f 0000 adb0 61ed 0000 0000
          0000230 ce24 0006 0000 0000 0000 0000 0000 0000
          I got a lot of events, even if I'm not pressing any buttons on the gamepad.
          For comparaison, here's what I got with an other gamepad (everything is ok with this one) :
          # hexdump /dev/input/event2
          I got nothing until I really press something on the gamepad.
          If I do an evtest for the Gamecube USB controller :
          # evtest
          No device specified, trying to scan all of /dev/input/event*
          Available devices:
          /dev/input/event0:	Power Button
          /dev/input/event1:	Power Button
          /dev/input/event2:	Generic X-Box pad
          /dev/input/event3:	HDA ATI HDMI HDMI/DP,pcm=3
          /dev/input/event4:	HDA ATI HDMI HDMI/DP,pcm=7
          /dev/input/event5:	HDA ATI HDMI HDMI/DP,pcm=8
          /dev/input/event6:	HDA ATI HDMI HDMI/DP,pcm=9
          /dev/input/event7:	HDA ATI HDMI HDMI/DP,pcm=10
          /dev/input/event8:	HDA ATI HDMI HDMI/DP,pcm=11
          /dev/input/event9:	Video Bus
          /dev/input/event10:	Generic   USB  Joystick
          /dev/input/event11:	HDA Intel PCH Front Mic
          /dev/input/event12:	HDA Intel PCH Rear Mic
          /dev/input/event13:	HDA Intel HDMI HDMI/DP,pcm=3
          /dev/input/event14:	HDA Intel HDMI HDMI/DP,pcm=7
          /dev/input/event15:	HDA Intel PCH Line
          /dev/input/event16:	HDA Intel PCH Line Out Front
          /dev/input/event17:	HDA Intel HDMI HDMI/DP,pcm=8
          /dev/input/event18:	HDA Intel HDMI HDMI/DP,pcm=9
          /dev/input/event19:	HDA Intel PCH Line Out Surround
          /dev/input/event20:	HDA Intel PCH Line Out CLFE
          /dev/input/event21:	HDA Intel HDMI HDMI/DP,pcm=10
          /dev/input/event22:	HDA Intel PCH Line Out Side
          /dev/input/event23:	HDA Intel PCH Front Headphone
          Select the device event number [0-23]: 10
          Input driver version is 1.0.1
          Input device ID: bus 0x3 vendor 0x79 product 0x6 version 0x110
          Input device name: "Generic   USB  Joystick  "
          Supported events:
            Event type 0 (EV_SYN)
            Event type 1 (EV_KEY)
              Event code 288 (BTN_TRIGGER)
              Event code 289 (BTN_THUMB)
              Event code 290 (BTN_THUMB2)
              Event code 291 (BTN_TOP)
              Event code 292 (BTN_TOP2)
              Event code 293 (BTN_PINKIE)
              Event code 294 (BTN_BASE)
              Event code 295 (BTN_BASE2)
              Event code 296 (BTN_BASE3)
              Event code 297 (BTN_BASE4)
              Event code 298 (BTN_BASE5)
              Event code 299 (BTN_BASE6)
            Event type 3 (EV_ABS)
              Event code 0 (ABS_X)
                Value    132
                Min        0
                Max      255
                Flat      15
              Event code 1 (ABS_Y)
                Value    126
                Min        0
                Max      255
                Flat      15
              Event code 2 (ABS_Z)
                Value    128
                Min        0
                Max      255
                Flat      15
              Event code 5 (ABS_RZ)
                Value    134
                Min        0
                Max      255
                Flat      15
              Event code 16 (ABS_HAT0X)
                Value      0
                Min       -1
                Max        1
              Event code 17 (ABS_HAT0Y)
                Value      0
                Min       -1
                Max        1
            Event type 4 (EV_MSC)
              Event code 4 (MSC_SCAN)
            Event type 21 (EV_FF)
              Event code 80 (FF_RUMBLE)
              Event code 81 (FF_PERIODIC)
              Event code 88 (FF_SQUARE)
              Event code 89 (FF_TRIANGLE)
              Event code 90 (FF_SINE)
              Event code 96 (FF_GAIN)
          Properties:
          Testing ... (interrupt to exit)
          Event: time 1642966590.330262, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966590.330262, -------------- SYN_REPORT ------------
          Event: time 1642966590.338261, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.338261, -------------- SYN_REPORT ------------
          Event: time 1642966590.458259, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966590.458259, -------------- SYN_REPORT ------------
          Event: time 1642966590.466267, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.466267, -------------- SYN_REPORT ------------
          Event: time 1642966590.482259, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966590.482259, -------------- SYN_REPORT ------------
          Event: time 1642966590.490258, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.490258, -------------- SYN_REPORT ------------
          Event: time 1642966590.602255, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966590.602255, -------------- SYN_REPORT ------------
          Event: time 1642966590.610256, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.610256, -------------- SYN_REPORT ------------
          Event: time 1642966590.618255, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966590.618255, -------------- SYN_REPORT ------------
          Event: time 1642966590.626255, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.626255, -------------- SYN_REPORT ------------
          Event: time 1642966590.730270, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966590.730270, -------------- SYN_REPORT ------------
          Event: time 1642966590.746252, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.746252, -------------- SYN_REPORT ------------
          Event: time 1642966590.754252, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966590.754252, -------------- SYN_REPORT ------------
          Event: time 1642966590.770251, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.770251, -------------- SYN_REPORT ------------
          Event: time 1642966590.866249, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966590.866249, -------------- SYN_REPORT ------------
          Event: time 1642966590.874248, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966590.874248, -------------- SYN_REPORT ------------
          Event: time 1642966590.994246, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966590.994246, -------------- SYN_REPORT ------------
          Event: time 1642966591.002244, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.002244, -------------- SYN_REPORT ------------
          Event: time 1642966591.138242, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966591.138242, -------------- SYN_REPORT ------------
          Event: time 1642966591.146259, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.146259, -------------- SYN_REPORT ------------
          Event: time 1642966591.266237, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966591.266237, -------------- SYN_REPORT ------------
          Event: time 1642966591.274237, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.274237, -------------- SYN_REPORT ------------
          Event: time 1642966591.546232, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966591.546232, -------------- SYN_REPORT ------------
          Event: time 1642966591.554230, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.554230, -------------- SYN_REPORT ------------
          Event: time 1642966591.562248, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966591.562248, -------------- SYN_REPORT ------------
          Event: time 1642966591.570230, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.570230, -------------- SYN_REPORT ------------
          Event: time 1642966591.674228, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966591.674228, -------------- SYN_REPORT ------------
          Event: time 1642966591.682214, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.682214, -------------- SYN_REPORT ------------
          Event: time 1642966591.698215, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966591.698215, -------------- SYN_REPORT ------------
          Event: time 1642966591.714215, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.714215, -------------- SYN_REPORT ------------
          Event: time 1642966591.802239, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966591.802239, -------------- SYN_REPORT ------------
          Event: time 1642966591.818240, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.818240, -------------- SYN_REPORT ------------
          Event: time 1642966591.826240, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966591.826240, -------------- SYN_REPORT ------------
          Event: time 1642966591.834238, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.834238, -------------- SYN_REPORT ------------
          Event: time 1642966591.938236, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966591.938236, -------------- SYN_REPORT ------------
          Event: time 1642966591.946237, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.946237, -------------- SYN_REPORT ------------
          Event: time 1642966591.954234, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966591.954234, -------------- SYN_REPORT ------------
          Event: time 1642966591.970234, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966591.970234, -------------- SYN_REPORT ------------
          Event: time 1642966592.074234, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966592.074234, -------------- SYN_REPORT ------------
          Event: time 1642966592.082219, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966592.082219, -------------- SYN_REPORT ------------
          Event: time 1642966592.210232, type 3 (EV_ABS), code 2 (ABS_Z), value 129
          Event: time 1642966592.210232, -------------- SYN_REPORT ------------
          Event: time 1642966592.218228, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966592.218228, -------------- SYN_REPORT ------------
          Event: time 1642966592.234229, type 3 (EV_ABS), code 2 (ABS_Z), value 127
          Event: time 1642966592.234229, -------------- SYN_REPORT ------------
          Event: time 1642966592.242233, type 3 (EV_ABS), code 2 (ABS_Z), value 128
          Event: time 1642966592.242233, -------------- SYN_REPORT ------------
          Again, lots of stuff even I don't even touch the controller.
          Now the evtest with my other gamepad :
          # evtest
          Available devices:
          Select the device event number [0-23]: 2
          Input device ID: bus 0x3 vendor 0x20d6 product 0x2802 version 0x101
          Input device name: "Generic X-Box pad"
          Supported events:
              Event code 304 (BTN_SOUTH)
              Event code 305 (BTN_EAST)
              Event code 307 (BTN_NORTH)
              Event code 308 (BTN_WEST)
              Event code 310 (BTN_TL)
              Event code 311 (BTN_TR)
              Event code 312 (BTN_TL2)
              Event code 313 (BTN_TR2)
              Event code 314 (BTN_SELECT)
              Event code 315 (BTN_START)
              Event code 316 (BTN_MODE)
              Event code 317 (BTN_THUMBL)
              Event code 318 (BTN_THUMBR)
                Value      0
                Min   -32768
                Max    32767
                Fuzz      16
                Flat     128
                Value     -1
                Min   -32768
                Max    32767
                Fuzz      16
                Flat     128
              Event code 3 (ABS_RX)
                Value      0
                Min   -32768
                Max    32767
                Fuzz      16
                Flat     128
              Event code 4 (ABS_RY)
                Value      0
                Min   -32768
                Max    32767
                Fuzz      16
                Flat     128
                Value      0
                Min       -1
                Max        1
                Value      0
                Min       -1
                Max        1
          Properties:
          Once again, nothing until I press something on the gamepad.
          Here I am right now... I guess it's weird that the faulty gamepad is generating that much events... or maybe not.
          juluss 1 Reply Last reply Reply Quote 0
          • juluss
            juluss @juluss last edited by
            Ok I think I might know why the usb gamecube controller is generating that much event. The axe #2 (yes, the c-stick left/right) is "shaky", meaning that the value keeps changing when I do nothing on the gamepad. But its osclillating between 127-129. And when I move the stick left or right, it doesn't change anything.
            • juluss
              Ok...
              So it's not the c-stick that is causing all the events, it might be the main one. When I put the main stick all to the left, events stop generating. But those events were for the c-stick. It's really weird.
              I also tried to cat the file for the device (/dev/input/js1) and even there, when I move c-stick left/right, nothing change. But it does for other buttons. So now I think unless I can install new drivers it's a lost cause. If I can't find a driver for this, I'm gonna return it.
              I see those problems as challenges but I also just want to play Gamecube 😄
                @juluss
                Normally this is not possible, a regular user cannot install anything in Recalbox.
                • juluss
                  juluss @Zing last edited by juluss
                  @zing said in Retrobit Gamecube controler : C-stick not working:
                  hmm ok... too bad.
                  Anyway I tried Batocera, to see how this one handles the gamecube controller. Well, the controller works perfectly on Batocera. The C-stick is working. Unfortunately, I was unable to configure a specific config file for Gamecube as I did with Recalbox. I'm back on Recalbox now.
                  So, after all that, I forfeit. Too bad for that controller, I won't use it. I might look for an other one, better, more compatible. Maybe the one for the Nintendo Switch, it would be nice to use it Bluetooth.
