    Specific input config for Gamecube
    GamePad/GPIO/USB encoder
    specific input config gamecube
    • juluss
      juluss last edited by
      Hi,
      I'm using Recalbox on my old gaming PC, and I have to say it's working pretty well. I can finally enjoy PS2 and GameCube games that I couldn't when these two consoles were the hit. I'm using a generic Xbox One controller, plugged in USB. I did setup it in Recalbox menu, mapping each button correctly.
      But, I'm having some trouble with controller configuration for Gamecube and PS2. Let's talk about GameCube first. The Z button of the GameCube controller should be R1 on my Xbox controller, right ? And the 2 analog trigger should be L2 and R2, right again ? But it's not. The Z button is R2, and the triggers are L1 and R1.
      So I'm trying to create a specific config file for the gamecube, following instructions here : https://wiki.recalbox.com/en/tutorials/controllers/configuration-of-customized-buttons/create-custom-configuration-per-emulator
      I'm trying the manual solution. So, here the config file I created :
      ~/configs/retroarch/gamecube.cfg
      And here's what's inside :
      input_player1_b_btn = 0
      input_player1_down_btn = h0down
      input_player1_joypad_index = 0
      input_player1_l2_btn = 4
      input_player1_l3_btn = 11
      input_player1_l_btn = 6
      input_player1_l_x_minus_axis = -0
      input_player1_l_x_plus_axis = +0
      input_player1_l_y_minus_axis = -1
      input_player1_l_y_plus_axis = +1
      input_player1_left_btn = h0left
      input_player1_r2_btn = 5
      input_player1_r3_btn = 12
      input_player1_r_btn = 7
      input_player1_r_x_minus_axis = -2
      input_player1_r_x_plus_axis = +2
      input_player1_r_y_minus_axis = -3
      input_player1_r_y_plus_axis = +3
      input_player1_right_btn = h0right
      input_player1_select_btn = 8
      input_player1_start_btn = 9
      input_player1_up_btn = h0up
      input_player1_x_btn = 3
      input_player1_y_btn = 2
      But when I launch a GameCube game, and go in the Dolphin config (HotKey+B), and I can see that the changes are not working.
      Can someone explain to me what I should put in the file ?
      Thanks !
      • juluss
        Ok nevermind guys, with a better search I found a post from ym that explain what to do
        https://forum.recalbox.com/post/143474
        Thanks to ym !
        Now I still have a similar problem with PS2 games. The D-pad is not working. For instance, I can't properly use it to select a track in Gran Turismo 4. Is there a way to check the config specifically for the PS2, and create a dedicated file if needed ?
        • juluss
          Ok so once again I figured out myself... I just set Recalbox to launch PS2 games with Libretro PCSX2 instead of PCSX2... and everything is working fine now.
          Ok, time to play now !
