    Using the joystick to adjust audio volume in MAME/Retroarch
    Emulator Arcade/PC/Console
    joystick adjust audio volume mameretroarch
    • ChrisK
      ChrisK last edited by
      Hi,
      I would like to be able to adjust the volume in MAME games by pressing the hotkey and moving the joystick up/down (which by default changes the save state slot). I've edited the retroarchcustom.cfg file (in share/system/configs/retroarch), deleting the lines:
      input_state_slot_decrease_axis = +0
      input_state_slot_increase_axis = -0
      and replacing them with:
      input_volume_down_axis = +0
      input_volume_up_axis = -0
      Now I find that moving the joystick changes both the volume AND the state slot. When I reopen the retroarchcustom.cfg file I can see that the two lines I deleted have reappeared.
      Is there any way I can permanently stop hotkey+joystick up/down from changing the save slot?
      olivierdroid92 Zing 2 Replies Last reply Reply Quote 0
      • olivierdroid92
        olivierdroid92 Global moderator @ChrisK last edited by
        @chrisk
        Hi
        Did you try with a surcharge ?
        https://wiki.recalbox.com/fr/advanced-usage/configuration-override#:~:text=Vous pouvez surcharger les configuration,les jeux d'un répertoire.
        ChrisK 1 Reply Last reply Reply Quote 0
        • ChrisK
          ChrisK @olivierdroid92 last edited by
          @olivierdroid92 I did try, but without success. However, I couldn't work out how to use a configuration override file to "cancel" an existing setting. What should I put in the override file to delete the default input_state_slot_decrease_axis and input_state_slot_increase_axis settings?
            Zing Global moderator Translator @ChrisK last edited by
            @chrisk Try something like this:
            input_state_slot_decrease_axis = "nul"
            input_state_slot_increase_axis = "nul"
