    Sf30 pro not pairing after disconnecting
    GamePad/GPIO/USB encoder
    sf30pro pairing
    • jor2404
      jor2404 last edited by
      Hi,
      When my sf30pro power off and then I power it on again it doesnt pair until I reboot recalbox the same matters with sn30pro
      Hoy can I solve it?
      kozmo403 Zing 2 Replies Last reply Reply Quote 0
      • kozmo403
        kozmo403 @jor2404 last edited by
        Having the same issue with an SN30 Pro+ controller. If I turn the controller off or reload the pi, I have to forget the controller and pair it again to get it to work.
        • jor2404
          If it helps I was using the same gamepads in old recalbox versions without problems
            Zing Global moderator Translator @jor2404 last edited by
            @jor2404 See if this helps:
            • https://forum.recalbox.com/topic/25352/recalbox-8-0-beta/41
            • https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/8bitdo-on-recalbox
