    Megadrive roms not showing
    Emulator Arcade/PC/Console
    megadrive roms showing
    2829
    • Azean
      Azean last edited by
      Not sure what is wrong but I'm having issues with with megadrive roms, none of them are showing, it's the only one I've had issues with having added roms to most of the others.
      I have done the usual thing of adding the roms in this case .md files into the SHARE/roms/megadrive folder but they don't show up event after updating the games list. Being new to this I'm not sure if there is something really obvious I've not done/done right, so any help would be great πŸ™‚
        @azean hi
        is your ES set on "gamelist only" ? Did you scrap the folder ?
        Is there a gamelist in the folder ?
        • Azean
          Hi @Scavy
          Nope there is no gamelist xml in the folder, I have used the scraper but doesn't seem to do anything and I'm not sure what ES stands for, sorry
          • Bkg2k
            Bkg2k Staff @Azean last edited by
            @azean Are your roms .md files?
            Azean 1 Reply Last reply Reply Quote 0
            • Azean
              Azean @Bkg2k last edited by
              @bkg2k Yep they are. I seem to have found a work around, manually write the gamelist xml, seems to do the job and now i know there i supposed to be one in the folder I thought I would try it, though I don't know why it didn't generate one automatically
              Thanks though
              Scavy Bkg2k 2 Replies Last reply Reply Quote 0
                Scavy Global moderator @Azean last edited by
                @azean it's not normal that there's no gamelist created.
                Did you try with an other format ? (zip... check the readme file in the megadrive folder).
                • Pitch64
                  Pitch64 Staff last edited by
                  It seems you have the issue with no .md file visible, it would be fine to confirm by testing others file extensions for this system.
                  Otherwise, this is an issue fixed for the next version - https://gitlab.com/recalbox/recalbox/-/issues/2085
                  Next release? Soonβ„’
                  • Bkg2k
                    Bkg2k Staff @Azean last edited by Bkg2k
                    @azean This bug is fixed in the next version.
                    Until then, just zip your roms: they take less spaces and .zip files work flawlessly πŸ™‚
                    • Azean
                      @bkg2k Thanks, I will do that πŸ™‚
                      Copyright Β© 2021 recalbox.com
