    Best arcade input
    GamePad/GPIO/USB encoder
    arcade input
    1243
    • 0zzy
      0zzy last edited by
      Hi, with recalbox 8 + rgb dual or similar board, GPIO ports are used for video signal, so, if i'm not wrong, we can not use them for arcade controls.
      In this case, which is the best way to connect arcade push buttons? Only external usb encoders? Which is better and why?
        Zing Global moderator Translator @0zzy last edited by
        @0zzy
        In fact, most users use GPIO for arcade controls...
        0zzy 1 Reply Last reply Reply Quote 0
        • 0zzy
          0zzy @Zing last edited by
          @zing me too, but with some adapter lile pi2scart i don't think there is a way to use them for controls, is it right?
            @0zzy
            Now I understand your question.
            Sorry, I've never used GPIO personally, but as far as I know there are some types of GPIO expander cards, and I'm guessing you can do it yourself (but it's easier to buy) like this:
            https://www.amazon.com/GeeekPi-Raspberry-Extension-Expansion-Screws/dp/B08C2XK25W
            I don't know if this brand/model is good, I don't even know what all the existing models are, as I've never used it, I can't recommend a specific brand/model, but as far as I understand, those who need GPIO for 2 purposes use something like that ...
            • 0zzy
              @zing said in Best arcade input:
              @0zzy
              Hi @Zing thanks for your reply.
              But there is something i dont have clear.
              Online there are a few image about gpio pinout used for arcade controls
              There are 40pins:
              24 are used for controls
              8 are gnd
              8 not used for this purpose
              Do you know which pins are used to pilot rgb and sync signals?
                @0zzy
                No, but you can look up this information in the manufacturer's official documentation if you want (I believe from this part down, but you can search the entire documentation):
                • https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#parallel-display-interface-dpi
