    Recalbox to a CRT screen with composite
    recalbox crt composite
    • wenderemilio
      wenderemilio last edited by
      Hi,
      I'm trying to make the latest version of Recalbox work on my tv. I'm using a Raspberry pi 2, a cable and a TV that works perfectly with Raspberry Pi OS. When I format the card and install Recalbox 8.0 it doesn't work.
      I've done the Wiki procedures and other posts here on the forum.
      Connect your Recalbox to a CRT screen with composite
      My configuration files are below:
      /boot/recalbox-user-config.txt
      /boot/config.txt
      /recalbox/share/system/recalbox.conf
      Thanks.
        Zing Global moderator Translator @wenderemilio last edited by
        @wenderemilio See if this helps:
        https://gitlab.com/recalbox/recalbox/-/issues/2059
        wenderemilio 1 Reply Last reply Reply Quote 0
        • wenderemilio
          wenderemilio @Zing last edited by
          @zing thanks for you answer. I made the settings as suggested and got pictures on the TV. But now I'm stuck on the same screen. EmulatioStation does not load. Log:
          [ 97.73] [emulationstation-starter] [ES] emulationstation exited code 134
          [ 97.74] [emulationstation-starter] [ES] started emulationstation (pid=2040)
          [ 98.65] [emulationstation-starter] [ES] emulationstation exited code 134
          [ 98.66] [emulationstation-starter] [ES] started emulationstation (pid=2053)
          I´ll keep trying.
          Thanks again.
            @wenderemilio The problem is already being analyzed by the developers and should be fixed in the next version, which will be released soon (but it still doesn't have a scheduled date).
            Please wait patiently and test with the new version as soon as it is released.
