    Bluetooth don’t found any device after first pairing
    GamePad/GPIO/USB encoder
    bluetooth don’t device pairing
    7674
    • duard
      duard last edited by
      Hi guys!
      I’m on raspberry pi 4, recalbox 8, ssd usb booting by nespi 4 case. I bought a csl nano bluetooth 4.0 because and connect it with a usb cable to avoid known bluetooth distance problems using usb 3.0. For the first time I had bluetooth csl dongle working all was fine, my ps4 dualshock works perfectly and the bluetooth distance issues an lagging disappear. The problem is that after that first pair, I can’t pair any other controller because now bluetooth is always saying “no controllers found”. The first paires ps4 controller still working very fine, but can’t pair any other by bluetooth. Any idea?
      • duard
        Just to give more info. When I did "Forget Bluetooth Controllers" it didn't work, so I always have the first paired controller detected and auto paired when reboot after apply the forget bluetooth controllers.
          Zing Global moderator Translator @duard last edited by
          @duard
          See if this helps:
          https://forum.recalbox.com/topic/24453/how-to-delete-or-clean-reset-all-found-controllers/6
          duard 1 Reply Last reply Reply Quote 0
          • duard
            duard @Zing last edited by
            @zing thanks for your response, I did it editing the conf file directly on a text editor on my mac so emulation station was stopped. When I reboot recalbox after that, the controllers list was empty but unfortunately bluetooth pairing was telling no controllers found. The strange thing is that I pushed the playstation button on my previously paired dualshock 4 and it pairs again automaticly so like if recalbox remember it. It is strange like for any reason this controller was not forgotten. I tried also disabling ertm but nothing works. Maybe it is related to my csl nano bluetooth 4.0 dongle? I bought it because it is in the compatible devices list.
            • charger
              charger Banned last edited by charger
              I have had the same problem for weeks, but it doesn't seem to affect its resolution: the problem is not linked to Bluetooth, it is related to recalbox which no longer allows any type of controller after something has been played and the controller has entered powersaving or is turn off. It doesn't matter what kind of controller you want to use next, virtual, bluetooth or wired. If you try, you will realize that even if you connect the gamepad via cable, the recalbox will still not be controllable.
              I do not understand how we can not notice a bug of this type, which I have been reporting for a long time.
              duard Zing iTiki 3 Replies Last reply Reply Quote 0
              • duard
                duard @charger last edited by
                @charger said in Bluetooth don’t found any device after first pairing:
                Hmmm for me usb works, the problem is only with bluetooth, first time I use csl dongle all works fine, but I don't know if from the next reboot or after pairing the first controller bluetooth no longer find any bluetooth device (my house is plenty of bluetooth devices to find further than of course the controller trying to pair). It's like I have this controller paired like hard chained but bluetooth don't work.
                charger 1 Reply Last reply Reply Quote 0
                • charger
                  charger Banned @duard last edited by charger
                  @duard
                  Try this:
                  • load recalbox
                  • connect gamepad via bt (ok, works)
                  • play some games (neogeo) --> VERY IMPORTANT
                  • back to ES
                  • turn off gamepad
                  • turn on again: does it reconnect? In my case, NO, NEVER
                  • try to connect via usb cable: does it works? NO
                  • try to use virtual gamepad: does it works? NO
                  Try that and let me know.
                  If I didn't play any games, gamepad reconnection works well even after turn off, virtual gamepad works, and even via usb cable... so the problem is recalbox, that after game quit, mess up something.
                  This issue happen with virtual gamepad, wired gamepad and bt gamepad...
                  With 7.2 at least virtual gamepad works again, so I was able to pair again controller without turn RPI4 off/on.
                  duard 1 Reply Last reply Reply Quote -1
                  • duard
                    duard @charger last edited by duard
                    @charger I don’t have Neo Geo games but I played mame, snes or whatever and then turn off the controller and turn on again and it pairs. But only with the one I paired the first time I connected the csl bluetooth dongle. My problem is that bluetooth don’t find any bluetooth device just the first I paired. Seems like something was wrong with the bluettoth management after connect the CSL dongle. @Zing do you know if maybe there is something to do with the csl nano bluetooth 4.0 dongle? I need to disable the internal bluetooth or whatever?
                    • charger
                      This is very strange (maybe due to dongle): I've even try with batocera and I haven't any problem at all, only with recalbox8.
                      So I think to move to batocera until this issue is fixed.
                        @duard
                        nespi 4 case
                        See if this helps:
                        • https://gitlab.com/recalbox/recalbox/-/issues/1309
                        • https://wiki.recalbox.com/en/tutorials/others/nespi4case-installation
                          Zing Global moderator Translator @charger last edited by
                          @charger
                          You're wrong, I don't have any problems with my joystick. And it's a cheap unbranded joystick.
                          It's not because you have a problem that you should generalize, please stop discouraging others just because you have a problem and you don't have the patience, if you keep doing this I will take more drastic measures.
                          Why? You seem to know something no one else does.
                          Following the same logic as you: for me it didn't happen, so you're wrong.
                          • duard
                            duard @Zing last edited by duard
                            @zing I followed this nespi 4 case installation tutorial when I installed the case just after a fresh install of recalbox 8 stable version. About the other topic, I think it is not related to my case.
                            Just for clarify, my CSL USB Nano Bluetooth V4.0 dongle is working always with the dualshock 4 paired in my first atttempt of using the bluetooth dongle, I can reboot, shut down and always will work even if I try to forget it through the Forget Controllers option or deleting manually through the config file with emulation estation stopped.
                            The problem is that trying to pair another one no controller is found, in fact the pairing process doesn't find any bluetooth device and it is sure that is not working well because previously when I tried to pair always have a 4 or 5 bluetooth devices in the list as well as the controller (my apple mouse, my phone, etc....).
                            So it is like the bluetooth don't do the job when I attempt to search for bluetooth devices.
                            @Zing what I can try this weekend is to do a new fresh install in a sd and try to begin from zero because I think something went wrong when the first auto configuration of my dongle was done the first time I connected it.
                            Thanks for your help! I will keep you updated!
                              @duard
                              I recommend you reset the joystick physically (there's a tiny button somewhere on the joystick, you need something like a toothpick to get it pressed). And, test without the Bluetooth adapter, as your test is about the pairing issue, not the lag.
                              • charger
                                charger Banned @Zing last edited by
                                @zing If that logic is good for you, so is good for me.
                                Recalbox is bugged, cause here doesn't works: so I discourage use it, cause official community doesn't help, but simply say "in my house, it works, so no problem".
                                Zing 1 Reply Last reply Reply Quote -1
                                  @charger I'm sure no one told you that, I'm sure the Recalbox community is better than other retrogaming systems, and I'm sure Recalbox is a great OS, for me it's the best.
                                  This is the Recalbox forum, offered to you for free, maintained by people helping for free, it's not fair that you try to mess up and belittle the service of others just because something doesn't suit you.
                                  If you're not here to help the community, then at least don't talk bad about Recalbox, don't discourage any more users, or I'll ban you.
                                  • iTiki
                                    iTiki @charger last edited by
                                    @charger
                                    I have this exact problem since upgrading to version 8. Wired, Bluetooth and my 8Bitdo arcade stick I was using with the 2.4 wireless dongle. None of them work after playing a game and disconnecting them. I’m forced to restart Emulation Station from Recalbox Manager to get it working again.
                                    charger Zing 2 Replies Last reply Reply Quote 0
                                    • charger
                                      charger Banned @iTiki last edited by Zing
                                      @itiki I'm sorry to heat that no one, in more than one week, has reply about that problem. I've post even debug logs, but nothing...silence.
                                      The only thing I got is being scolded because I wouldn't be cooperative....
                                        @charger
                                        The problem is being properly analyzed by the developers, we have a small team of developers who do their best to better serve. You are not being ignored as you imply.
                                        Yes, and you will be scolded again if you insist on an anti-collaborative attitude.
                                          Zing Global moderator Translator @iTiki last edited by
                                          @itiki Remap your joystick in the emulationstation to ensure it's not just a mapping problem.
                                          8Bitdo arcade stick
                                          Please check if this helps:
                                          • https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/8bitdo-on-recalbox#arcade-style-controllers
                                          • https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/8bitdo-on-recalbox#faq
                                          iTiki 1 Reply Last reply Reply Quote 0
                                          • iTiki
                                            iTiki @Zing last edited by
                                            @zing
                                            I've tried remapping but it doesn't work. On a fresh boot or a restart of Emulation Station the controllers work perfectly. However, if I play a game then leave or unplug the controller and plug it back in, the controller is completely unresponsive, it doesn't matter what kind of controller is connected or by what method.
                                            On the 8Bitdo's the light on the controller even shows its connected but it is completely unresponsive.
                                            This has only happened since I upgraded to version 8. Before this I had no issues with any of the controllers, and even now they work fine... as long as I don't unplug them or let them go to sleep.
                                            Prior to this the only weirdness I experienced with my SN30 pro+ was that while is one of the game/system lists the list would randomly jump around between games. No issues playing the games or while in the main screen. This issue still exists but not a deal breaker. The controller connection issue has become a major headache, I'm hoping this gets fixed in the next update.
