    Disabled gamepad in duckststion
    Emulator Arcade/PC/Console
    disabled gamepad duckststion
    1678
    • IGA
      IGA last edited by
      Hardware: Pi 4 - 4gb
      Power supply: 5V 3A Power Supply
      Recalbox 8
      Built From: Pre made from website pi4 image
      USB: logitech keyboard
      Controller: saitek x-box 360 controller
      VideoOut: crt-tv via composite !
      Solute!
      Could somebody say to me how configurate gamepad in duckstion core? It disabled when run games....
      As it stand alone emu i could not get RA settings
      Well, i took usb-keyboard to try configurate it, press Esc - entered to menu:
      alt text
      Then chose "exit game" and entered next menu:
      alt text
      Chose - Settings, appear next menu:
      alt text
      Ok, but how could entered to buttons mapping menu from this by keyboard??
      • Deleted by  IGA IGA
      • Restored by  IGA IGA
      • IGA
        IGA last edited by IGA
        Now with experiments with config files i've lost ability to enter in QuickMenu ( esc on keyboard) - it lost and not worked now....
        And what a difference between E:\system\duckstation.cfg and E:\system.config\duckstation\settings.ini ?
        It's the same file? In both:
        [Hotkeys]
        FastForward = Keyboard/Tab
        OpenQuickMenu = Keyboard/Esc
        but when press Esq nothing happened now....
        So where required configurable file?
        • Pitch64
          Pitch64 Staff last edited by
          This is a bug we spotted and a fix is planned to use only 1 ini file 🙂
          Next release? Soonâ„¢
          IGA 1 Reply Last reply Reply Quote 1
          • IGA
            IGA @Pitch64 last edited by IGA
            @pitch64 said in Disabled gamepad in duckststion:
            So it means that there's nothing else I can do on my own with this?
            And I should calm down and and do other things? or....?
              Zing Global moderator Translator @IGA last edited by
              @iga The issue is being checked out by the developers, so unfortunately you need to be patient and wait for the next version to be released.
              It shouldn't take long, however, there is still no set release date.
              • IGA
                IGA @Zing last edited by
                @zing Ou..., Thank you for answer!
                And then I spent the whole day yesterday poking around in these configs\inis, but there's no sense - thank you for saving me from further torment, I'll go to bed with a clear conscience )
