    Unmount Network Drives.
    MediaCenter & Dualboot
    unmount network drives
    • phreatic
      phreatic last edited by
      Hi, I have a multi boost system made using PINN. I opted for this because Recalbox 7.2.2's Kodu would not seem to work with CEC. Recalbox 8 electron came out while I was building it, so I'm using that.
      PINN lets you set Recalbox to boot back to the Kodi system installed (I have Libreelec and OSMC ) when selecting Kodi, instead of using the 'native' Recalbox one.
      I also have the Recalbox 'SHARE' folder on a NAS.
      So far so good, occasionally the drive doesn't mount but that's ok.
      My problem is that when it does mount and i select reboot to Kodi, Shutdown or reboot, it hangs on the screen warning you to wait before turning off. I'm suspecting that it's because the network share is not being dismounted, but I can't find anywhere to dismount it.
      Many thanks
        Zing Global moderator Translator @phreatic last edited by
        @phreatic See if this helps:
        https://wiki.recalbox.com/en/tutorials/network/share/roms-on-a-network-share-samba-nas
        phreatic 1 Reply Last reply Reply Quote 1
        • phreatic
          phreatic @Zing last edited by
          @zing thankyou for your suggestion, I think the instructions I had used were derived from that page but I'm not sure.
          Anyway, what I tried was to mount the drives individually instead of using 'SHARE' and I did not bother with screenshots, userscripts (I had unsuccessfully tried a script to unmount all drives on SHUTDOWN) and music as I have nothing in them and it works as expected.
          Thanks again
          Paul
