    Atari 2600 black screen on second load
    atari 2600 black screen second load
    • FedeKrum
      FedeKrum last edited by FedeKrum
      Hi,
      If you power up your RBPi and open an Atari 2600 game, you will play with no problem. You may go back to the ES menu.
      But if you open the same game again, you get a black screen.
      Can anyone confirm this?
      Thanks
      FedeKrum 2 Replies Last reply Reply Quote 0
      • FedeKrum
        FedeKrum @FedeKrum last edited by
        Using a RBPi Zero W2
        • FedeKrum
          The issue is not present if you try the older hardware model ( in my case the RBPi Zero W)
            Zing Global moderator Translator @FedeKrum last edited by
            @fedekrum I saw that you have already opened an issue:
            https://gitlab.com/recalbox/recalbox/-/issues/2060
            Developers will check it out as soon as possible.
