    help with gamecon snes pi
    GamePad/GPIO/USB encoder
    help gamecon snes
    • luisbigpapa
      luisbigpapa last edited by
      I have a problem, I am building a pi snes. when activating the gamecon controls it works fine only for a few minutes then it starts to go crazy and finally stops working. I have tried it with version 7.2.2 and with 8 beta and the problem is the same, I already checked the solder and actually changed the raspberry pi (both pi4, one of 2gb and one of 8gb), will someone have the solution?
        Scavy Global moderator @luisbigpapa last edited by
        Hello @luisbigpapa
        Could you post a picture and the model of your pad ?
        luisbigpapa 1 Reply Last reply Reply Quote 0
        • luisbigpapa
          luisbigpapa @Scavy last edited by
          @scavy of course the model is SNS-005 American version
