    Broken Laptop Screen!
    broken laptop screen
    • wonko
      wonko last edited by
      I read this post because my laptop screen is broken. My recalbox instance is installed on the laptop hard drive.
      Editing the .conf file sounds easy enough but I don't know how to get there.
      I can see the MAIN menu well enough to go through those options but I don't see a way to get to the file system. I don't see any display options to change under 'UI Settings'. Any suggestions as o how I can use an external monitor connected via HDMI?
      THanks!
        Zing Global moderator Translator @wonko last edited by
        @wonko said in Broken Laptop Screen!:
        • https://wiki.recalbox.com/en/basic-usage/getting-started/recalboxconf-file
        • https://wiki.recalbox.com/en/tutorials/system/access/network-access-winscp
        • https://wiki.recalbox.com/en/tutorials/system/access/recalbox-manager-web-interface
        • https://www.youtube.com/watch?v=pxq_8RXSRjg&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=46&ab_channel=Recalbox
        • https://www.youtube.com/watch?v=Bt4aHZ2Xo2g&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=39&ab_channel=Recalbox
        • wonko
          wonko last edited by wonko
          Thank you for the links. Part of the problem is, whenever I try these solutions, I am trying them on a broken screen and I can only see the left side. I decided to try booting from usb into a Ubuntu live environment and edit the .conf file from there.
          wonko 1 Reply Last reply Reply Quote 0
          • wonko
            wonko @wonko last edited by
            @wonko I was able to edit the .conf file, this line:
            ;system.externalscreen.prefered=
            I deleted the ;
            I tried these values after the equal sign:
            hdmi-0
            hdmi-1
            hdmi-2
            hdmi0
            hdmi1
            hdmi2
            No luck! I guess I will look at some more of those tutorials.
            • wonko
              wonko @wonko last edited by wonko
              @wonko I ran this in Ubuntu : xrandr |awk '/connected/{print $1,$2}'
              And verified that it is HDMI-0
              and it worked! I have Recalbox running on the external screen - thank you for the help!
