    T2 ARCADE- FBNEO- INPUT NOT SAVING
    Emulator Arcade/PC/Console
    arcade fbneo input saving
    • Gutz316
      Gutz316 last edited by
      Hello, I am having some issues saving the controller configs for the Terminator 2 Arcade shooting game in particular in the Libretro Fbneo settings.
      I am using a PI 4 with the standard Recalbox 7.2 latest update.
      Other Final Burn Neo Roms such as Beast Busters / Zero Point work straight away with all the settings configured for the use of the wii mote and dolpin bar.
      With Terminator 2 the Arcade Game for example, I enter the input menu through the settings, enter into the Port 1 option, change the Device Type to light gun, set the Mouse index to 2 + configure the trigger button and game works.
      Problem is that when I exit the game and enter again, all changes made in the input settings revert back to original (mouse index / trigger) however device type still shows as lightgun.
      I save the controller profile / game remap file after making changes prior to exiting the game.
      Can I please confirm the following;
      When making changes to the input, is it sufficient to just save the controller profile and game remap file or am I required to also save / select another option.
      Anyone else have this issue or have been able to make changes permenant.
      Any assistance is appreciated.
      Thank You
      Ronald
        Zing Global moderator Translator @Gutz316 last edited by
        @gutz316
        https://wiki.recalbox.com/en/tutorials/controllers/configuration-of-customized-buttons/how-to-customize-controller-mapping
