    Retroarch hotkey overloading overload
    GamePad/GPIO/USB encoder
    retroarch hotkey overloading overload
    • Tamalock
      Tamalock last edited by Tamalock
      Hey everyone!
      I just spent hours trying to figure out the chain of config files, overloads and automatic overwritings happening and I don't feel like I'm any closer to understanding the mess.
      I'm trying to set some different hotkeys for ANY core loaded into Retroarch through Recalbox (installed on a PC)
      I've tried editing:
      retroarchcustom.cfg
      retroarchcustom.cfg.overrides.cfg
      retroarch-core-options.cfg
      Under both the share partition and the root partition
      I've tried setting per core .cfg file and pointing to them in recalbox.conf
      I just can't figure out what is overriding what. It seems like Recalbox is auto overriding any changes done to .cfg files under the share partition, but it's not using the ones inside the root partition because any edits to those never transfer over.
      So where exactly are the defaults coming from? For example let's say I want to set input_menu_toggle_btn to 10 for ALL cores loaded through Retroarch - how do I get Recalbox to set that automatically when it does its overwrite of retroarchcustom.cfg?
        Zing Global moderator Translator @Tamalock last edited by
        @tamalock
        You need to read the documentation:
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads
        Path: /recalbox/share/roms/.retroarch.cfg
        With the text:
        input_menu_toggle_btn=10
