    problem applying recalbox theme or intro.
    recalbox
    • gheharukoh7
      gheharukoh7 last edited by
      Good evening,
      (I edit my message) well I'm obviously moving forward I knew how to apply a theme but it still bugged and I don't even know how to see my play list.
      So I imply like it's been said elsewhere that it is necessary find themes at the correct resolution of the terminal I suppose ...
      So, how can we know which theme works with a particular bartop suddenly ?
      Sr for my bad english
        Zing Global moderator Translator @gheharukoh7 last edited by
        @gheharukoh7
        You need to use the latest version of Recalbox (currently 7.2.2), and use a theme compatible with that version:
        • https://forum.recalbox.com/topic/24510/recalbox-7-2-2-thèmes-compatibles
        The resolution has to be consistent with your TV's resolution and the power of your device (at an Rpi0 it's useless to try to use a 1080p theme).
        If in doubt, use a 720p theme.
        If that doesn't work, use a 480p theme.
        If none works, keep the default theme.
        To test it, use the Next Pixel theme:
        https://forum.recalbox.com/topic/16064/next-pixel-theme
