    V4.0.0 beta 2 issues.
    v4.0.0 beta issues
    • matttzilla
      matttzilla last edited by
      Hey guys. i just got my pi3 and I set up recalbox and it runs like a champ! I love it. Im new to this, I'm just now getting my feet wet. But there is a few issues I was wondering if anyone else had a fix for or was  experiencing  themselves. 1. Mame, when I go to map the start key and coin key it will not recognize the  buttons on the controller. Controller is a rock candy Xbox 360. 2. When I map keys in ES they work perfect. Now when I got to a n64 rom for  instance the "b" button is now the "y" button. 3. When I try to add psx Roms they fail and say size is to large cant upload. The sizes are only like 4-500 mb. Now it will start then stop and disappear really quick. 4. And last. Every gba bios I try to add fails. Incorrect file or format. Thanks guys. I appreciate any help.
        Hello @Matthew
        1. Mame, when I go to map the start key and coin key it will not recognize the buttons on the controller. Controller is a rock candy Xbox 360. 2. When I map keys in ES they work perfect. Now when I got to a n64 rom for instance the “b” button is now the “y” button.
        can you enable xboxdrv into recalbox.conf and disabled ps3 driver ? https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN) configuration of the controllers in recalbox is based on the SNES buttons assignment use mapping buttons for snes pad. https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#2---xbox-360-controllers
        controllers.ps3.enabled=0
        ## Choose an driver beetween official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
        controllers.xboxdrv.enabled=1
        reboot rpi.
        Use winscp to transfert psx roms. tutorial not complete in english : https://github.com/recalbox/recalbox-os/wiki/Network-access-with-WinSCP-(EN) tutorial complete https://github.com/recalbox/recalbox-os/wiki/acces-via-WinSCP-(FR)
        https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN) need bios with correct MD5
        - GAMEBOY ADVANCE :
        a860e8c0b6d573d191e4ec7db1b1e4f6  gba_bios.bin
        https://github.com/recalbox/recalbox-os/wiki/Check-md5-checksum-(FR) Use also recalbox-manager to drop bios file : https://github.com/recalbox/recalbox-os/wiki/recalbox-manager-WEB-interface-(FR)
        • matttzilla
          AWESOME. So far every thing has work thank you so much!
