    How to setup dedicated buttons for savestate/loadstate/exit game actions ?
    setup dedicated buttons actions
    • Faboz
      Faboz last edited by
      Hi everyone !
      I am new to recalbox, and I struggle doing something that might be easy:
      I designed my arcade machine to have 3 buttons on the top of the players, so that they can smash them to save the current state or load the last state or even quit.
      So both players can hit that button, or even a spectator which is great fun. And it is easier to explain to child compare to the hotkey combination tricks.
      And... I can't get how to do this. All special actions seems to use the hotkey. Can't have a dedicated button ?
      Any direction ?
      Thanks for reading !
      Faboz
        Zing Global moderator Translator @Faboz last edited by
        @faboz
        See if this helps:
        https://recalbox.gitbook.io/documentation/tutorials/controllers/gpio/activate-the-gpio-button-to-close-the-emulator-by-pressing-a-single-button
        Faboz 1 Reply Last reply Reply Quote 0
        • Faboz
          Faboz @Zing last edited by
          @zing Thanks !
          Your link is a good ressource, it is specific to the exit button, so it's a good start. Also it worries me a bit: it shows that what I am trying to do is not that trivial.
          Must mention in the discord someone suggested to connect my custom button to both existing buttons (hotkeys and start for instance to exit). It would work for sure, but I am not really fan of this solution as if a player is sending any input with his pad at the same moment, this will activate others hotkeys...
          Thanks again for your link
            @faboz This other link may also be useful to you:
            https://forum.recalbox.com/topic/20853/home-button-project
