    Mupen64 Problem No Z trigger
    Emulator Arcade/PC/Console
    mupen64 zbutton inputautocfg
    • Dragon
      Dragon last edited by
      I want to use the N64 Emulator and my N64 USB controller works fine but there is the little problem the Z button doesn't work. If I modify the inputautocfg.ini the original file exists again after restart. The problem is that the Z button isn't defined in the original file...
        Zing Global moderator Translator @Dragon last edited by
        @dragon Please use the forum's search tool and check if one of the many posts talking about N64 controls helps you:
        • https://forum.recalbox.com/topic/9016/a-lire-manettes-n64
        • https://forum.recalbox.com/search?term=n64&in=titlesposts&matchWords=all&sortBy=topic.lastposttime&sortDirection=desc&showAs=posts&page=1
