    Change screen ratio menu recalbox
    ratio recalbox
    • polandluigi
      polandluigi last edited by
      I have my recalbox connected to a 16:9 7 inch screen via HDMI. Is there a way I can force the Menu screen to fit to a 4:3 scale on my screen? At the moment the menu is widescreen, and would prefer it to be forced into a 4:3 ratio. Is there a different config file to be edited please?
        Zing Global moderator Translator @polandluigi last edited by
        @polandluigi Check the Emulationstation menu, there are several different options, one of them is the screen ratio, there is even a "perfect pixel" option (I'm not sure of the right term in English), which forces the game to its original resolution.
        polandluigi 1 Reply Last reply Reply Quote 0
        • polandluigi
          polandluigi @Zing last edited by
          @zing I don't mean games. I want to change the Recalbox aspect ratio. It is possible?
          • polandluigi
            polandluigi @polandluigi last edited by
            @polandluigi said in Change screen ratio menu recalbox:
            @zing I don't mean games. I want to change the Recalbox aspect ratio. It is possible? I use rasbery pi 3A+
              @polandluigi Yes, it is possible, you can change the videomode in the recalbox.conf file, or you can go further and change it in the recalbox-user-config.txt file (you will find several topics talking about the config.txt file, but the file recalbox-user-config.txt keeps your changes after an upgrade, config.txt does not).
              See this:
              https://recalbox.gitbook.io/documentation/tutorials/video/display-configuration/complete-guide-on-video-configuration
