    mame problem
    Emulator Arcade/PC/Console
    mame
    • Ctdonithan
      Ctdonithan last edited by
      Games work fine but there is no sound when playing any of the games when i can play any of the other systems and sound works fine its just with the mame/arcade games
        Zing Global moderator Translator @Ctdonithan last edited by
        @ctdonithan Arcade has a peculiarity: you need to check the ROMSET (the "version" of the ROM).
        Example: MAME 2003 ROMS work with MAME 2003 core, MAME 2010 ROMS work with MAME 2010 core. The vast majority of games exist in both versions, and even other versions, but you need to have your ROMSET anyway that be the version of the core you are using.
        About ROMSET, here is the list of used ROMSETs:
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/generalite/les-roms-et-les-isos/les-romset-pour-recalbox
        The ideal is to convert your ROMSET with programs like ROMULUS or CLMAMEPRO:
        • https://recalbox.gitbook.io/documentation/tutorials/utility/rom-management/romulus-tutorial
        • https://recalbox.gitbook.io/documentation/tutorials/utility/rom-management/clrmamepro-tutorial
        Some users find it easier to download complete ROM packages from the internet, in the desired ROMSET, but it is prohibited to request or share any kind of copyrighted material on the forum, so please do not request it.
        Also you need all the correct BIOS, in the Emulationstation menu there is a BIOS checker, use it to find out which BIOS you need and where they should be placed. BIOS is also copyrighted, so you need to do this yourself.
        I recommend that you read the documentation about ARCADE:
        • https://recalbox.gitbook.io/documentation/v/francais/usage-avance/l-arcade-dans-recalbox
        RustyMG 1 Reply Last reply Reply Quote 0
        • RustyMG
          RustyMG @Zing last edited by RustyMG
          Yeah, agreed.
          Its hard to "get your head round", but, a good example is Point Blank.
          My MAME rom / zip file had no audio but played fine.
          Had to get a hold of a different rom that would only load via MAME2010, but has perfect audio.
          Re looking for romsets, obviously we cant give links, but, I will say that google or torrent sites these days are not the best places to look.
          Do a search in youtube for MAME romset and you will see what i mean.....
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
