    How to add system to main menu
    main
    • TheWhite
      TheWhite last edited by Zing
      Hi,
      I am trying to add PSP Mini to the main menu. I have added es_systems.cfg to \\RECALBOX\share\system\.emulationstation with the following:
      <?xml version="1.0"?>
      <systemList>
      <system>
         <name>pspminis</name>
         <fullname>PlayStation Portable Minis</fullname>
         <path>/recalbox/share/roms/pspminis</path>
         <extension>.iso .pbp .cso .ISO .PBP .CSO</extension>
         <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE% -ratio %RATIO% %NETPLAY%</command>
         <platform>psp</platform>
         <theme>pspminis</theme>
      <emulators>
      <emulator name="ppsspp">
      <cores>
      <core>ppsspp</core>
      </cores>
      </emulator>
      </emulators>
       </system>
      </systemList>
      The system shows in the menu but the games will not load, they do work if I copy them into the PSP rom folder. I have to manually change the emulator to PPSSPP for it to try to start. But if goes back to the main screen. Also if I set it to PPSSPP from the main menu under emulator settings it does not change anything. I still have to manually edit the game to use PPSSPP
      Also how do I put a main menu graphic for that system. Currently only shows the text. Thank you.
      I searched for several hours and cannot find a clear answer on how the es_system.cfg should be written out for Recalbox 7.2.2 as from my understanding you cannot change the file under share_init. You have to make a new file and add new entry under \\RECALBOX\share\system\.emulationstation
        Zing Global moderator Translator @TheWhite last edited by
        @thewhite I can't test this right now, apparently you're following the correct idea, according to the tutorial:
        https://recalbox.gitbook.io/documentation/advanced-user/configuration/display-of-systems
        Did you copy the PSP entry from the es_systems.cfg file and modify it, or did you copy it from another system (SNES for example)?
        PSP is a standalone emulator, I can't confirm at this point if there is any difference, but it is a possibility.
        I recommend that you also read these topics.:
        • https://forum.recalbox.com/topic/17186/problem-custom-es_system-cfg
        • https://forum.recalbox.com/topic/23152/order-in-which-the-systems-appear-in-the-main-menu
        TheWhite 1 Reply Last reply Reply Quote 0
        • TheWhite
          TheWhite @Zing last edited by
          @zing Ok great I changed the NAME to PSP as I read that it has to match one of the systems in the original es_systems or it will not launch. The games now launch. Now even though I set ti to use PPSSPP in the advanced menu I still have to manually change the emulator to PPSSPP for each game and then it launches?
            @thewhite
            This shouldn't be necessary, but if it is, you can edit this in the gamelist, the easiest is to use external software like Skraper or ARRM:
            • Skraper:
              https://www.youtube.com/watch?v=G388Gc6kkRs&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=22&ab_channel=Recalbox
            • ARRM :
              https://forum.recalbox.com/topic/11850/arrm-another-recalbox-roms-manager?_=1609592968003
            Or, what should be even easier, is to make a Configuration overload file:
            • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
