    Read-only Recalbox? Defined games for Screensaver?
    read-only recalbox defined screensaver
    • tekkenism
      tekkenism last edited by
      Greetings.
      I've set a Recalbox system with retro games (RPi4) for my cousins. They always mess up with the system settings, delete games from the lists.
      Is there any way to set Recalbox system into read-only mode? I mean, nothing should be changed or deleted.
      My second question is; Is it possible to define a game lists for screensaver? I mean, it starts completely random games, but I'd like to set a list of games the Screensaver would use.
      Thank you for all!
      Zing 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @tekkenism last edited by
        @tekkenism Are you building Recalbox yourself, or have you downloaded a ready-made image from the internet?
        What version of Recalbox are you using (say version, don't say "latest")?
        tekkenism 1 Reply Last reply Reply Quote 0
        • tekkenism
          tekkenism @Zing last edited by
          @zing Using 7.2.2-Reloaded, and not compiled by myself, downloaded image file for RPi4 from Recalbox.com website.
            @tekkenism
            Using 7.2.2-Reloaded, downloaded image file for RPi4 from Recalbox.com
            It is not possible to delete games via Emulationstation in Recalbox 7.2.2, so either you are not using the official 7.2.2 version, or your cousin is deleting directly from your SD card.
            If you are not using the latest official version (7.2.2 at the moment), we cannot support you.
            If you are using the latest official version, but your cousin is knowledgeable enough to delete games directly on the SD card, there will be no configuration available in Recalbox to prevent this.
