    Cracking sound
    Emulator Arcade/PC/Console
    cracking sound
    • Joey0621
      Joey0621 last edited by
      Hi! I'm noticing cracking sound in retroarch based emulators and nothing I try fixes it. Sound in the menu works fine as in Daphne but not in retroarch. My setup is a pi 4 4gb connected via hdmi to component at 240p.
        Zing Global moderator Translator @Joey0621 last edited by
        @joey0621
        Have you tested directly via HDMI to make sure the problem is not converter?
        Even if you think the problem isn't the converter, test it on a TV with HDMI to see what happens.
        Joey0621 1 Reply Last reply Reply Quote 1
        • Joey0621
          Joey0621 @Zing last edited by
          @zing when I get home I'll try but I also tried outputting sound through the audio jack and got the same issue.
