    Recalbox 7.2.2 Overclock
    Your recalbox
    recalbox 7.2.2 overclock
    3300
    • MrGamer
      MrGamer last edited by
      Hi all,
      i have a GPI Case with Recalbox 7.2.2
      Is there somewhere a menu for overlock as described in the wiki? Or is there another way to overklock?
      Best Regards
      Zing recalboxfan1 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @MrGamer last edited by
        @mrgamer https://recalbox.gitbook.io/documentation/basic-manual/getting-started/preparation-and-installation-of-recalbox/retroflag-gpi-case#can-i-overclock-my-pi-0
        MrGamer 1 Reply Last reply Reply Quote 0
        • MrGamer
          MrGamer @Zing last edited by
          @zing : you mean with config.txt?
          There i see the following:
          overclocking settings are automatically managed in this file
          do not remove this line, nor edit the file
          include recalbox-oc-config.txt
          and in this file i see
          No overclocking
          But no clue what to enter here
            @mrgamer
            That's what the documentation says, but you're right:
            The documentation is out of date and we are working on new documentation, so the information is not as accurate.
            The correct file is recalbox-oc-config.txt
            We can't provide accurate overclocking support, it's a risky procedure that the user needs to be aware of (and need to use heatsink at least in the case of GPI case that doesn't have space for a fan).
            The best I found to help you is:
            https://www.raspberrypi.org/forums/viewtopic.php?t=249071
            • MrGamer
              @zing Thanks for the link!
              I totally understand that you can not provide here any tips and i am aware of the risk. But ok, at least i can loose 15€ for a new pi zero 😉 not nice but could be more 🙂
              How is the usage of this file? Same parameters which i would put into config.txt?
              Thanks and Best regards
                @mrgamer
                I am always careful to make this very clear as some user may read this in the future and I don't want to be held responsible for trying to help someone...
                i can loose 15€ for a new pi zero not nice but could be more
                “I am envious of you", unfortunately in my country these boards are much more expensive, so I only have an Rpi3. 😢
                Exactly, both the recalbox-oc-config.txt file and the recalbox-user-config.txt file have the "same usage" as the config.txt file, with the difference of keeping the values after a system update (the config file .txt is updated along with the system and loses all customizations).
                • MrGamer
                  @zing 15€ is only for Pi Zero. The other ones are also much more expensive. Here i am much more carefull. This pains a bit 😉
                  thanks for your help!
                  • recalboxfan1
                    recalboxfan1 @MrGamer last edited by
                    @mrgamer said in Recalbox 7.2.2 Overclock:
                    Is there somewhere a menu for overclock
                    Yes, it’s under “Advanced Settings”. I think that’s the name….I promise it says “Advanced” somewhere at least 😃
