    Bluetooth headphones / 7.2.2
    bluetooth headphones 7.2.2
    2690
    • andypiper
      andypiper last edited by
      According to the release notes, Recalbox 7.2 introduced BT audio support via the "Bluetooth settings->Pair a BT controller" option. I completed that successfully, but the audio out is continuing to go via "analog output". (I am running on a Pi Zero W in a Retroflag GPI case). The headphones do not show up in sound settings. Am I missing something?
        Scavy Global moderator @andypiper last edited by
        @andypiper hello
        To pair a BT audio media, you have to use the pairing mode of the pads.
        Once it's paired, it should automatically works.
        andypiper 1 Reply Last reply Reply Quote 1
        • RustyMG
          RustyMG last edited by
          Ooooh I didn't realise this!
          So, although its headphones, you have to pair it as a bluetooth gamepad ?
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
            Scavy Global moderator @RustyMG last edited by
            @rustymg i didn't try with headphones but with a loudspeaker and it works fine. I guess it should be the same for BT headphones ^^
            • andypiper
              andypiper @Scavy last edited by
              @scavy can you walk me through this? I’ve found the headphones in the Bluetooth controller pairing options, and it seems to complete, but I don’t get the audio out. Sorry for not understanding 😕 thanks for any additional advice!
                Scavy Global moderator @andypiper last edited by Scavy
                @andypiper Hi,
                i just tried with my Sony XB41 loudspeaker.
                i launched the pairing on it, i launched a research of BT devices in the pad menu in recalbox, when it was found in the list, i chose my XB41 speaker, it automatically paired.
                In the sound menu, you can also find the speaker (or headphones) once it's appaired. Just select it if it's not.
