    Stuck on welcome screen in Odroid Go Advance v2
    stuck odroid advance welcome screen oga
    • Proco
      Proco last edited by Proco
      I downloaded the latest version of Recalbox (7.2.2-Reloaded) for my OGA v2 and when the welcome says 'press any button' is stucked, I pressed all the buttons from my OGA and nothing happens. My OGA is OK (I have another SD with EmuELEC and it's working just fine). Below you can find a short video.
      https://imgur.com/2NFQ2fE
        Zing Global moderator Translator @Proco last edited by
        @proco Weird, this usually happens when the problem is physical, but if it works on another system it doesn't seem to be the case...
        And the SD card? What brand/model/size is it?
        Recommended is an original class 10 SD card. If possible, test with another SD card, or even formatting and reinstalling the system to ensure there was nothing wrong with the flash process.
        Proco 1 Reply Last reply Reply Quote 0
        • Proco
          Proco @Zing last edited by Proco
          @zing You're totally right. Using a newer and faster MicroSD and works like a charm.
          Thanks! Now I can use Recalbox on my RPi 3B+ and in my OGA and trasnfer the .srm files between them.
