    Where's Mame roms?
    Emulator Arcade/PC/Console
    wheres mame roms
    • Plugin32
      Plugin32 last edited by
      Hi, I downloaded the new version of Recalbox on a new microSD card and transfer all the content of the old roms directory on the new card and put the new SD in my raspberry pi 3. And now in the Mame section, I don't have any of the 1000 something that I've before on the old SD card but I see all of the other roms from other console... I need help to figure what I miss... Thanks!
        Zing Global moderator Translator @Plugin32 last edited by
        @plugin32 I don't know which version of Recalbox you had before, but the mame folder still has the same name, so this shouldn't be a problem.
        I can say that some folders were renamed, like fba emulator was upgraded to fbneo, the folder was renamed too, and I think this happened with other emulators (but I don't remember all the changes).
        I think your problem may be with the fba and fbneo folder, not the mame folder, please check.
        Plugin32 1 Reply Last reply Reply Quote 0
        • Plugin32
          Plugin32 @Zing last edited by
          @zing Hi! My old version was 18.07.13 It was stuck to this version and unable to update it so that's why I wanted to start from scratch. In the roms folder of the old version I have fba and fba_libretro only and same things in than the new SDcard and in those there a few file and a gamelist but don't have a lot of game like the others console. But when I enter old SDcard in the Pie3, I can play the games but with the new SD I don't see any games... Thanks
            @plugin32
            fba_libretro
            There is no longer the fba_libretro folder, the fbneo folder has taken its place. No ROMs from the fba_libretro folder will be recognized because that folder no longer exists.
            Read this:
            https://forum.recalbox.com/topic/22052/installing-older-final-burn-on-new-recalbox-version
            • Plugin32
              @zing Thanks for your help. I'll reinstall those in the for the new version.
