    Cannot configure 3rd party Nintendo Switch Pro controller - IINE Wireless Controller
    GamePad/GPIO/USB encoder
    cannot configure 3rd party nintendo
    • Brad
      Brad last edited by OyyoDams
      I'm trying to configure this controller (https://www.aliexpress.com/item/1005001504377391.html?spm=a2g0o.productlist.0.0.1c9b6196SQ3LWl&algo_pvid=2cb020db-c20f-40ae-ae7c-08438bec1dbc&algo_exp_id=2cb020db-c20f-40ae-ae7c-08438bec1dbc-7) with Recalbox 7.2.2-Reloaded on a Raspberry Pi 4B (2 GB RAM).
      I'm using a Logitech wireless keyboard with a USB unifying receiver to navigate the menus.
      The controller pairs ok via Bluetooth but then a message shows in the top right advising that it needs configuring. When I attempt to configure it, the screen shows:
      CONFIGURE INPUT
      1 GAMEPAD DETECTED
      HOLD A BUTTON ON YOUR DEVICE TO CONFIGURE IT.
      PRESS ESC OR THE HOTKEY TO CANCEL.
      I tried holding a b**ton on the controller but nothing happens.
      When I plug the controller in via USB, it detects as a XBOX360 controller.
      Would this controller not be compatible via Bluetooth?
        Zing Global moderator Translator @Brad last edited by
        @brad
        Probably... There are thousands of hardware and drivers and the team can't test them all, if it's incompatible, there's not much you can do besides file an issue:
        https://gitlab.com/recalbox/recalbox/-/issues
        But, before opening an issue, try doing a factory reset (available through advanced settings), you will not lose any personal files, but you will lose all custom settings.
        See if this helps:
        • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuring-custom-buttons/how-to-customize-controller-mapping
        • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuring-custom-buttons/create-a-custom-configuration-by-emulator
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads
        • https://forum.recalbox.com/topic/24237/ps3-controller-muting-kodi/16
